03-23-2015, 01:35 PM   #1
Card issues with my K5IIs
Hi Folks,
Anyone have any issues with their cameras (my K5IIs) not reading their camera cards right? I keep getting "Memory Card Error" no matter what card I put in there be it full, no images, or my (hope this didn't break it) my new wifi Toshiba card. Thoughts?
Please help.
Thanks,
Ron
03-23-2015, 01:49 PM   #2
UncleVanya's Avatar
Have you checked the cards in another camera or computer?
03-23-2015, 01:51 PM   #3
jatrax's Avatar
Card errors are fairly rare. Open the SD door on the camera and inspect the area carefully, make sure there is no debris or dirt there. Check the cards to see if any have broken edges. Do the cards read OK in the computer? Have you formatted the cards in the camera? Do they work in a different camera?
03-23-2015, 04:29 PM   #4
QuoteOriginally posted by ronuser Quote
Is there any chance, any chance at all that your card was used on a card reader and was not properly ejected (unmounted) before removing the card? Alternatively, was your card ever formatted with your computer's operating system software?
If the answer is yes to either question, download the formatting software from the SD Association Web site and use it to format your card.
https://www.sdcard.org/downloads/formatter_4/
Once done, the camera should recognize your card and you can reformat using the camera.
03-23-2015, 04:51 PM   #5
Yep...they all work fine in my K30 and PC. Sending it in.
---------- Post added 03-23-15 at 05:29 PM ----------
To clarify, I shoot a fair amount and have 8-9 different SD cards. 5-6 gave me the same message whether they had images on them, or not. All of those cards worked fine in my k30 and pc. I also checked the lock on them, camera door and as much as I could see in the slot. A repair guy I know said it's not uncommon for a contact inside to go. He was referring to the 35's slr in general, not just Pentax. Well see. Ricoh told me to send it to a shop in Conn called Precision camera. Still under Warranty. I'll keep you all posted, thanks - Ron
03-24-2015, 02:42 PM   #6
emalvick's Avatar
Have you tried formatting at least one of the cards in question using the K5iis?
You never mentioned the capacity of the cards. I mention this because it catches my attention that the cards work on a K30 but not on a K5iis. It looks like both cameras should support SDXC cards, but perhaps only after firmware updates? It does seem odd.
03-24-2015, 06:27 PM   #7
The cards range from 1 - 64gb. All fine in the other camera and PC. Unable to format in the K5, or click with. It's at the repair shop :-(
camera, card, card issues, cards, issues, k30, k5iis, pc, pentax help, photography, sd card issues in my k5, troubleshooting
Nature Playing with my K5IIs charliezap Post Your Photos! 10 01-13-2015 08:31 PM
Nature Couldn't do this with my K5iis nomadkng Post Your Photos! 7 09-11-2014 04:55 PM
Streets My street at night, first ever shot with my K5iis Partagas Post Your Photos! 2 05-13-2013 07:11 AM
First shots with my new K5iis ve2vfd Pentax K-5 3 04-22-2013 10:11 AM
k5IIs came with a sliver! -- metal filing in card slot... help close-enough Pentax K-5 14 10-31-2012 06:10 AM
All times are GMT -7. The time now is 09:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
