04-03-2015, 04:48 PM   #1
help! new lens won't work on old dslr?
I am using a beat-up old pentax k200d. I've been using it with the old manual lenses I had from my trusty k1000. I decided to splurge for a new lens yesterday and got the smc pentax DA 35mm 2.4AL. I can't get it to work on my k200d. It won't adjust aperture at all. I've messed with settings all day with no luck. Is it not compatible?
04-03-2015, 05:09 PM - 1 Like   #2
Buff the contacts on the body lightly with a microfiber cloth and try it again.
04-03-2015, 05:34 PM   #3
That helped a little --- I was able to get it to focus and take pictures but only in bright outdoor light. It still won't open up the aperture.
So it's supposed to be compatible but my camera is just not working? Highly possible --- it is rather beat up.
04-04-2015, 04:25 AM   #4
What other lens(es) do you use on your K200? If you do have/use other DA lenses, and they work ok, then it could be a problem with the DA35. Try cleaning the contacts on it, as you did on the camera body.
Also, as you mention using old film era lenses, you might want to check the settings on your K200. I can't help with which ones, or even if they matter, but setting up your camera for manual lenses might have affected how non-manual lenses perform.
camera, k200d, lens, pentax, pentax help, photography, troubleshooting
Firmware up dates won't work - Help! GAjeeperGirl Troubleshooting and Beginner Help 8 12-06-2014 08:21 PM
Sigma 150-500mm lens AF won't work DC Cebula Troubleshooting and Beginner Help 15 05-17-2014 11:36 AM
AF won't work on k200D with kit lens. mdlarsson Troubleshooting and Beginner Help 10 10-17-2009 02:57 PM
HELP! Extension tubes won't work ctt Pentax SLR Lens Discussion 9 08-11-2009 04:36 PM
Old SLR Lens Work on DSLR Camera? TexasTom Pentax SLR Lens Discussion 9 11-04-2007 10:59 AM
All times are GMT -7. The time now is 07:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
