04-08-2015, 11:39 AM   #1
GrimWolf's Avatar
Sigma 70-300mm f4-5.6 APO DG Macro
On monday just gone I was out with my new Sigma 70-300mm f4-5.6 APO DG Macro lens at a nearby nature reserve, However just about every photo I took came out slightly blurred (see attached). I was shooting at 1/250 shutter speed. Was this too slow, or is ir possible there a lens fault? Also, is it possible to rescue the photos in photoshop or lightroom?
04-08-2015, 11:46 AM   #2
jimr-pdx's Avatar
At first glance it looks like out of focus more than movement blur. Can you shoot manual focus on something solid then shoot it again with AF? Many camera bodies can adjust focus when a lens and body aren't matching uip
04-08-2015, 11:53 AM   #3
normhead's Avatar
This is what your images should look like....
close (on a tripod)
far , 1/500s hand held (well braced)
further, exposure time 1/45
<Slideshow of images taken with this lens. Click>
04-08-2015, 12:35 PM   #4
GrimWolf's Avatar
QuoteOriginally posted by jimr-pdx Quote
I had auto focus on with the camera, through the viewfinder it did seem to be focused.
04-08-2015, 01:06 PM   #5
Like Jim I think this looks out of focus rather than shake - have you tried shooting in liveview (also what camera were you using?)
04-08-2015, 01:09 PM   #6
GrimWolf's Avatar
Im using a k20d. Not tried live view. Do i need to caliberate the lens?
04-08-2015, 01:36 PM   #7
normhead's Avatar
I happen to have a K20D, and a Sigma 70-300 (and lucky for you, an acceptable woodpecker at my feeder, like how strange is that?) so I went out and tried it with the shutter set to 1/250s, hand held in really bad light. Here's the result. I don't see how the lens would be that bad even if it needed calibrating. I'd shoot a couple more test shots, and if you can't get it to work return it. I took 23 images and checked them all to see if any were like what you have, and there were no issues in any of them, from my perspective it has to be the lens.
You're absolutely sure the camera wasn't set to MF, and the lens wasn't set to macro? (even though on mine the macro setting doesn't seem to do anything.)
04-08-2015, 01:52 PM   #8
I certainly found with my K-r that it had focus issues with reflex viewing a critical focus object that LV coped with much better. But I have to say your picture looks very out of focus and I'm not sure that any amount of focus fine adjustment will sort this
04-08-2015, 02:53 PM   #9
GrimWolf's Avatar
I think i'll give the lens one more go on friday as there are ducks, swans and other birds locally. I'll try out different speeds and tripod etc. If it comes out the same, I'll return the lens and look at another model.
04-08-2015, 04:24 PM   #10
MarkJerling's Avatar
I have the same lens, and I find I get best results with shutter speeds faster than 1/400. Having said that, you may want to do a few tests by setting up the camera on a tripod and shooting at inanimate objects and see what results you get.
04-08-2015, 04:28 PM   #11
Emperor and Senpai
VoiceOfReason's Avatar
I have the lens and my only complaint is some CA in certain circumstances.
04-08-2015, 04:45 PM   #12
SpecialK's Avatar
I always had much better results as well. It did die an aperture-blade death on the shelf, however.
04-08-2015, 04:48 PM   #13
GrimWolf's Avatar
QuoteOriginally posted by MarkJerling Quote
I've set up with tripod with much the same results.
04-08-2015, 05:18 PM   #14
QuoteOriginally posted by GrimWolf Quote
In that case, I'd suggest there may be a problem with the lens.
04-08-2015, 08:52 PM   #15
sterretje's Avatar
I think the K20D has live view; try that. If that works, you can try to calibrate the AF (in camera); somewhere in the menus. But it seems to be off by a lot so you might not be able to correct it completely.
Were your tests controlled tests? Steady (relatively large) subject at similar distance as the shot you posted? Center point AF selected and aimed at the subject? Be aware that the focus point is relatively large (just a little smaller than the round brackets in the viewfinder), so if the subject is small, it might well have missed that and aimed at something behind or in front of the subject.
70-300mm f4-5.6 apo, apo, camera, dg, f4-5.6, f4-5.6 apo dg, lens, macro, pentax help, photography, sigma, sigma 70-300mm f4-5.6, troubleshooting
For Sale - Sold: Sigma 70-300mm F4-5.6 APO DG Macro SointulArt Sold Items 6 05-04-2014 11:26 AM
For Sale - Sold: Sigma 70-300mm f4-5.6 APO DG Macro ducdao Sold Items 5 02-17-2012 05:35 PM
Sigma 70-300 1:4-5.6 DL Macro vs Sigma 70-300mm F4-5.6 APO DG MACRO (Comparo) adr1an Pentax SLR Lens Discussion 7 05-08-2011 06:46 PM
For Sale - Sold: Sigma 70-300mm F4-5.6 APO DG Macro (Worldwide) montoblan Sold Items 5 09-18-2010 12:40 AM
All times are GMT -7. The time now is 09:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
