04-08-2015, 05:49 PM   #1
Help
I have a friend that bought a converter for a nikon lens to pentax camera body. She said she heard it click like a regular lens does. She said she used it a couple of times then went to take the lens off the converter and it is stuck. In the process of try to get the lens off the adapter the little button broke off. Does anyone have any ideas on how to get them seperated?
04-08-2015, 07:17 PM   #2
patrick9's Avatar
I just tried taking my adapter off my Nikkor 24mm. I had to play with it a while to get the button to release. It has always turned hard just prior to locking to the lens. She might try a small pocket screwdriver to pull the pin down to release the lens Insert it in the button area . I had to wiggle my lens and adapter a bit to get the pin where it would release so she may need to do that as well while pulling the pin down.. Also remember Nikon lenses twist on backwards of Pentax. Hope this helps and good luck
04-08-2015, 08:57 PM   #3
UncleVanya's Avatar
Spark plug feeler gauge - the kind with individual metal strips.
04-09-2015, 02:59 AM   #4
Lowell Goudge's Avatar
As opposed to turning the lens to remove it, turn it back slightly to put it on, and see if there is a little play in the locking pin, maybe it has some pressure on it, from use (focusing etc. ) that has been taken up and made the pin tight in the licking slot
04-09-2015, 03:04 AM   #5
If she heard click, then it's probably not friction (or not only friction) holding the components together. As others above have suggested, look up videos and articles on how to remove stuck lenses with a 'ricoh pin'. This could be a similar situation.
04-09-2015, 04:05 PM   #6
AquaDome's Avatar
Don't forget, the Nikon lens turns the opposite direction (compared to Pentax) to remove it from the adapter.
04-11-2015, 08:48 PM   #7
Thank you
Thank you patrick9, I used a small screw driver and pushed the button stub down and was able to get it right off. Thanks again
04-12-2015, 12:11 PM   #8
Aaron28's Avatar
very handy indeed!! what I used to remove a lens with the dreaded ricoh pin before I knew about it
camera, converter, lens, pentax help, photography, troubleshooting
help with lens newbie78 Pentax SLR Lens Discussion 6 02-01-2014 05:20 PM
wireless flash help nfraser Pentax K-30 & K-50 8 01-11-2014 01:51 PM
SP2 - Mirror return problem - Help pls! GBNeil Pentax Film SLR Discussion 13 10-18-2013 09:19 PM
ME super help ap_exclamationpoint Pentax Film SLR Discussion 9 05-15-2013 10:21 AM
General business help? Bcrary3 Photographic Industry and Professionals 9 05-09-2013 07:42 PM
All times are GMT -7. The time now is 02:46 PM. | See also: NikonForums.com, part of our network of photo forums!
