04-10-2015, 05:30 PM   #1
shutter problems
Hi, I am extremely new to this. I bought a Honeywell Pentax Spotmatic today. I've never used this type of camera. I am learning as I go. My current problem is my shutter. It keeps sticking. I take a picture, I advance the film, then I can not see anything through the viewer. What am I doing wrong???
04-10-2015, 05:43 PM - 1 Like   #2
Caver's Avatar
QuoteOriginally posted by trinityofgrace Quote
Just a guess, but that's more likely the mirror remaining in the up position - and blocking the view. This can happen with old cameras - as the foam from the inside of the camera (supposed to dampen the mirror) becomes sticky with time... If this is the case then you need a cleaning and sort of refurbishing of the worn parts.
04-10-2015, 05:51 PM - 1 Like   #3
jatrax's Avatar
Most cameras of that age will need a CLA (clean, lubricate, adjust). This was normal for cameras then, they were designed to last a very long time but did require maintenance. As noted by @Caver the seals are starting to decay and get sticky and they will need replaced. You can buy kits online to replace them or have the camera sent it for a complete CLA. I would suggest the CLA if you just got it, often it will need lubricated & adjusted as well.
04-11-2015, 08:49 AM   #4
Thank you both very much !!!! That is exactly the problem! I will call a shop to do the CLA. I do not trust myself to do it, lol.
camera, pentax help, photography, shutter, troubleshooting
K-5 shutter problems emtor Pentax K-5 10 11-17-2014 02:34 AM
Pentax MZ-5 Shutter Problems MightyJRC Pentax Film SLR Discussion 4 05-11-2014 04:40 PM
ist ds shutter and focusing problems swcgrtra Troubleshooting and Beginner Help 8 12-08-2013 05:56 AM
K200D Shutter Problems? FotoPete Pentax DSLR Discussion 6 02-27-2010 09:03 AM
Slow shutter problems. HowLowCanYaGo Pentax DSLR Discussion 7 07-23-2007 05:12 AM
All times are GMT -7. The time now is 12:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
