04-12-2015, 12:04 PM   #1
K5 will not power up
I bought a used K5 about 2 weeks ago. I snapped about 200 photos over that time and I have to say I absolutely love this camera. But unfortunately I went to use my camera last night and it would not turn on. Here is what happens. I turn it on and I get a sound as if the shutter is working. The LCD panel lights up for about 1/4 of a second. I can see the battery indicator showing I have a full charge, then it shuts down and will not do anything. I can turn it off and it will do the same thing again when I turn it on. I took put the battery put it on the charger just to make sure then put it back in and I got the same thing. I cleaned the contacts on the battery and still nothing. I thought about buying another battery but thought I would ask before doing that. Please help!!
04-12-2015, 12:21 PM   #2
It's quite possible that the battery is no longer good, especially if it wasn't used regularly in the past. It's also possible but unlikely that the electronics in the camera have gone bad.
04-12-2015, 02:14 PM   #3
demondata's Avatar
The sound that you hear may be the sensor cleaning mechanism, which can be activated at start-up as desired, or not. Pity you can't even turn it off. If the battery is very near it's end of like, that sensor cleaning action may just suck the last bit of juice out of it. I'd get another battery - the aftermarket ones can be quite good, depending, and you'd probably need a second one anyway.
04-12-2015, 02:47 PM - 1 Like   #4
crewl1's Avatar
Make sure the card door is closed, the camera won't turn on if it is open.
04-12-2015, 03:23 PM   #5
robgski's Avatar
QuoteOriginally posted by crewl1 Quote
Exactly! I've forgotten to put in an SD card and close the door, and though my camera was broken, fortunately it was only me.
04-12-2015, 04:45 PM   #6
Thank you very much for the information. As it turns out the SD card door was open. After reading this I looked to make sure all the doors were closed. When I closed the SD card door it started working again as it should. Again thank you for the valuable information.
04-12-2015, 04:56 PM   #7
The forum members here (me excluded) are very knowledgeable and willing to share that infomation. I've learned a lot here just by reading.
04-12-2015, 09:26 PM   #8
sterretje's Avatar
QuoteOriginally posted by Bryce K Quote
So now you're also knowledgeable
04-12-2015, 09:35 PM   #9
crewl1's Avatar
QuoteOriginally posted by kaju Quote
Glad you got it sorted.
battery, camera, k5, pentax help, photography, troubleshooting
K5 IIS Focus Points Not Showing Up DavidDwight Troubleshooting and Beginner Help 7 10-08-2014 02:57 PM
K5 battery depletion message/shutter will not fire Scenesaver Pentax K-5 8 01-26-2014 08:09 AM
remote will not work on my K5 Pete C Troubleshooting and Beginner Help 7 12-23-2013 02:49 PM
K5 will not work with SLR lens; why? wlwlad Pentax K-5 3 08-24-2013 12:43 PM
Help K10D Will not Power on !!! daacon Pentax DSLR Discussion 31 12-11-2007 12:35 AM
All times are GMT -7. The time now is 12:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
