Originally posted by steurm Hi again,
In the meantime I'v tried to set the 'slowest' shutter speed which works. It's around 1/1600. However, it results in under exposured pictures. Could this mean that a light sensor is faulty ?
I'm not quite sure what you mean (I know that this was originally my suggestion and I was not specific), when you speak of the "'slowest' shutter speed that works." In your original post you reported being able to take pictures in dark settings but not in bright settings. That suggests to me that you are able to take photos at slower shutter speeds but not at faster shutter speeds and that 1/1600 would seem to be more likely the fastest shutter speed that works, but that you get under exposed pictures at that speed.
I assume you were trying this in shutter priority mode so that the camera's only options for adjusting exposure (if it needs adjusting) is to change the lens aperture and/or the ISO setting. The lens aperture cannot open wider than it's widest setting (which on the 18-55mm kit lens will be between 3.5 - at 18mm - to 5.6 - at 55mm) and the ISO setting can only be changed by the camera if you have auto-ISO enabled, and then it will only vary between the ISO range you specify. So it is possible that this under-exposed photo was under exposed at 1/1600 was under exposed because the camera had reached its widest aperture setting and highest specified ISO. In that case you could always try a higher ISO setting. However, you should have gotten an exposure warning in the form of a blinking light on the EV display on both the view finder and status screen. This can be overlooked (I've done so several times myself).
I do not think the light sensor is at fault because you report that the camera will take photos in dark settings but not in bright settings, and also it appears to determine a correct exposure in bright settings but then the camera refuses to take the photo (but it will in dark settings). This suggests to me that the sensor itself seems unlikely to be at fault. However, if you are certain that you do NOT get an exposure warning in a situation such as the one you suggest in your example of the 1/1600 photo, then that might lead me to reconsider the sensor as being at fault.
If the shutter were somehow at fault (since it is refusing to take the photo), it does not make sense that the shutter will work in some situations and not in others.
It could be that your problems might be related to some obscure settings somewhere (such as having to do with white balance, custom image settings, dynamic range) or to some electronic or mechanical problem (since you have already re-installed the firmware, we will assume that the firmware is not at issue here). However, I am at a loss as how to best proceed.
Perhaps someone else has better insight into this.
I'll continue to think about this but I am not optimistic. If you do have more information to add, please feel free to post it.
Best wishes,
