04-20-2015, 01:09 PM   #1
Jake21209's Avatar
K-5 and multi-exposure
How do I cancel multi-exposure on my K-5? I use a tripod and the cable release/switch CS-205 and I currently save in DNG & JPEG. For some reason, the camera is now running in multi-exposure all of the time. I have gone through the operating manual and could not find a way to stop the multi-exposure. I generally use either TV or M mode.
04-20-2015, 01:31 PM   #2
jatrax's Avatar
On k-3 it is part of the drive mode menu. Arrow up on the keypad. I think it was the same on the k-5. Arrow up and set to single exposure.
04-20-2015, 01:47 PM   #3
Yes, arrow up is correct for K-5. Just make sure you are not moving af points instead. In that case long press the ok button first.
04-20-2015, 01:54 PM   #4
Stone G.'s Avatar
QuoteOriginally posted by Jake21209 Quote
On the K-5 multi exposure is part of the Recording Menu (page 2). Pressing the menu button twice - or more crudely - turning the camera off and on again *should* definitely bring you back to the normal drive mode.
If not, then it is rather weird indeed and I would suggest that you try a reset (Set-up Menu,page 3 on the K-5).
QuoteOriginally posted by kenny47 Quote
Not really if you already are in Multi Exposure mode on a K-5. In that case Arrow-up just toggles between 'Start Shooting* - 'Number of Shotts' - Auto EV Compensation'. Here, you must press the menu button twice to get out of that mode.
04-20-2015, 01:57 PM   #5
Jake21209's Avatar
Got it, thanks a lot.
Jay
camera, k-5, multi-exposure, pentax help, photography, troubleshooting
Tutorial for K-3 multi exposure modes: (Additive, Average and Bright)? zantaphia Pentax K-3 16 09-05-2016 01:18 PM
Live View and Multi Exposure Tjompen1968 Pentax K-3 13 12-27-2014 12:24 PM
K50 Multi exposure and astrophotography quedecree Pentax K-30 & K-50 4 12-10-2014 12:47 PM
K-3 multi exposure and interval composite Painter Pentax K-3 33 10-30-2014 10:47 AM
Long exposure shots, ND filters and multi-exposure averaging rrstuff Photographic Technique 17 10-19-2013 12:50 PM
All times are GMT -7. The time now is 06:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
