04-21-2015, 03:19 AM   #1
My macro lens is not working with my camera
I have a Pentax ist DL2 camera which I have many lenses for. My macro lens which I have used many times before although it has been a number of years since I used it now does not wish to work for me. I have tried several times to take photos yesterday and it will not take a picture, it feels as if the camera was in the off position which of course it wasn't. Can anyone give me any advise as to get this lens up and running again as I would like to use it for my forthcoming gardening holiday in 3 weeks time
04-21-2015, 04:10 AM   #2
QuoteOriginally posted by veronmiller Quote
It would REALLY help to know exactly what lens you are trying to use.
Without knowing that all our possible help will be vague.
Regards
Chris
04-21-2015, 04:13 AM   #3
Bruce Clark's Avatar
Back to basics.
What lens is the camera not working with?
Is it autofocus, if so what type of autofocus?
Is lens a compatible type?
If lens is older type eg M42, has menu setting to allow camera to operate been set correctly
What lenses it it working with?
What precisely is not working on lens or camera, auto focus, shutter, aperture, display?
Ensure fully charged battery
Ensure camera turned on
Ensure the drive door is closed
Is there sufficient capacity on disk drive
Check camera working with other lenses.
Clean lens and camera contacts with microfibre cloth
Set AF switch in correct position.
04-21-2015, 04:26 AM   #4
Na Horuk's Avatar
Yep, we need more info. And Bruce gave you a nice list of diagnostics.
What I would do is make sure the battery is charged, leave it outside of the camera for a couple hours. Make sure the camera and lens mount/contacts are clean and free of particles, grime. Check the SD card, make sure the contacts are clean, there is no dust in the slot. Then go into camera's Menu and Enable aperture ring (towards the end of the Menu). When mounting the lens, make sure it is fully mounted, it has to click into place. If the lens has an aperture ring, make sure it is in the A position (you might have to press a button to get it there. If the lens has no A on aperture ring, simply leave it at a number, like f5.6)
04-24-2015, 03:21 AM   #5
QuoteOriginally posted by seventhdr Quote
Regards
Chris
Thank you all for your responses. The lens I am trying to use is a macro Vivitar which I have used with this camera before without problems. The batteries are fully charged, on custom setting under aperture ring, it is permitted. I have tried my other lenses and they all work perfectly, so I am baffled as to why it no longer wishes to work. I tried it on auto as well as manuel settings.
04-24-2015, 03:41 AM   #6
Is the camera in AF mode? If so, it will only release the shutter if it confirms focus. Try setting it to MF.
04-25-2015, 02:34 AM   #7
Thank you for your advise, I set the camera to MF and now it is working. Many thanks, I can now go out and take the many spring flowers in the garden
camera, lens, macro, macro lens, pentax help, photography, times, troubleshooting
My camera is almost the size of my toaster with my D-BG4 Battery Grip disco_owner Pentax Camera and Field Accessories 24 05-09-2012 12:44 AM
AF not working--is it camera or lens? amc654 Troubleshooting and Beginner Help 14 01-17-2012 08:05 AM
Why isn't my ASAHI lens working with my K-x? Brian K Pentax DSLR Discussion 2 12-30-2011 04:22 PM
Is my 12-24 working right or not? mtngal Pentax SLR Lens Discussion 5 02-24-2011 08:37 PM
Pentax k-x not working with my tamron lens, or older pentax lenses Evanmackmusic Pentax DSLR Discussion 5 06-04-2010 03:24 AM
All times are GMT -7. The time now is 11:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
