i kind of noticed that too when I went out for a shoot last weekend-it look like for some shots, the original hood might not be enough. Would it be recommended to use a bigger lens hood? What is your experience with that? Thanks!
---------- Post added 04-25-15 at 08:22 AM ----------
Originally posted by Na Horuk Purple fringing is another thing. Its complicated, but fairly easy to correct with software
Lateral CA can be corrected in-camera if you shoot jpeg. If you shoot raw, most PP software will let you fix it as well.
Axial CA can be corrected in the final version of Lightroom I think, but not in the older versions.
Could you give me an advice where to find more info? I tried some youtube videos to remove CA or purple fringing in Photoshop, but they didn't fix CA or PF successfully. I'd appreciate if you can give a couple links to learn
Thanks!
