Originally posted by bdery Seems about right.
That's normal. Because the movement is not linear doesn't mean it's broken.
Sure? Because it also seems that the amount of zoom between 200-250 is less than the equivalent between, say, 150-200. It's odd.
Still a lovely lens, but..
edit: And, I mean, the optical zoom, not the movement of the barrel.
---------- Post added 04-24-15 at 12:07 PM ----------
Originally posted by jatrax That is correct. Hardly any movement after 200mm. Also note that at close distances you will not get 250mm, that is only at infinity due to the way the lens works. Great lens, it gets a lot of use from me.
Okay. Thanks jatrax. That puts my mind at ease if you also have the same thing.
It is a great lens. Useful for all kinds of things.
Reason: addition
