04-29-2015, 11:09 AM   #1
k5 iis and 16-45 overexposure
Hello.
I was unofficial photographer of bike race and lot of pictures came out like this. First one is good and second is not.
Exif is same (f 6.3, iso400).
I didn't realized i had one big stain on lens (i guess i spill it with iso drink).
Today i tested camera and took 250 photos and everything is fine. What do you think ? I hope is just drink lol
Second glitch is camera resets aperature when is off to f 8.0 - not always but sometimes.
Camera is still under warranty.
04-29-2015, 11:15 AM   #2
jatrax's Avatar
No EXIF so it is hard to tell. What metering mode were you using?
04-29-2015, 11:31 AM   #3
Multi segment metering.
First:
Make - PENTAX
Model - PENTAX K-5 II s
Orientation - Top left
XResolution - 300
YResolution - 300
ResolutionUnit - Inch
Software - K-5 II s Ver 1.07
DateTime - 2015:04:25 08:49:10
Artist -
YCbCrPositioning - Co-Sited
Copyright -
ExifOffset - 706
ExposureTime - 1/1000 seconds
FNumber - 6.30
ExposureProgram - Aperture priority
ISOSpeedRatings - 400
ExifVersion - 0230
DateTimeOriginal - 2015:04:25 08:49:10
DateTimeDigitized - 2015:04:25 08:49:10
ComponentsConfiguration - YCbCr
ExposureBiasValue - 0.00
MeteringMode - Multi-segment
Flash - Flash not fired, compulsory flash mode
FocalLength - 21.00 mm
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 1000
ExifImageHeight - 662
InteroperabilityOffset - 54468
SensingMethod - One-chip color area sensor
FileSource - Other
SceneType - Other
CustomRendered - Normal process
ExposureMode - Auto
White Balance - Auto
FocalLengthIn35mmFilm - 31 mm
SceneCaptureType - Standard
Contrast - Hard
Saturation - Normal
Sharpness - Hard
SubjectDistanceRange - Distant view
GPS information: -
GPSVersionID - 2.3.0.0
Maker Note (Vendor): -
Mode - Auto
Quality - 5
ISO - 400
Lens Type - smc PENTAX-DA 16-45mm F4 ED AL
Thumbnail: -
Compression - 6 (JPG)
XResolution - 300
YResolution - 300
JpegIFOffset - 54610
JpegIFByteCount - 6727
Second:
Make - PENTAX
XResolution - 300
YResolution - 300
DateTime - 2015:04:25 08:49:09
Artist -
Copyright -
ExifOffset - 706
FNumber - 6.30
ExifVersion - 0230
DateTimeOriginal - 2015:04:25 08:49:09
DateTimeDigitized - 2015:04:25 08:49:09
ColorSpace - sRGB
FileSource - Other
SceneType - Other
ExposureMode - Auto
Contrast - Hard
Saturation - Normal
Sharpness - Hard
GPS information: -
Mode - Auto
Quality - 5
ISO - 400
Thumbnail: -
XResolution - 300
YResolution - 300
JpegIFByteCount - 6946
04-29-2015, 12:27 PM   #4
I you have taken 250 shots in aperture priority and they have all been ok then chances are things are ok and this was just a glitch.
It appears from your two photos however, that something was definitely not right at that point in time, because they share the same shutter speed, aperture and ISO (and lighting conditions were exactly the same). This suggests that either your shutter fired slower than it should have, or the aperture did not stop down as far as it should have. I would say that the most likely of these is the latter, and can be caused by sticky or slow movement of the aperture blades. If any drink got inside the lens then that could definitely cause this. However, this is jumping to conclusions. Try opening and closing the aperture manually with the lever on the lens mount and see if there is any slowness.
04-29-2015, 12:50 PM   #5
I just tried that and it seems fine. I dont know, if this happens again I wil conatct service centre
04-29-2015, 01:25 PM   #6
What do you have the ISO set at Fixed or Auto ? Also what mode AV, TV, P etc.
Oops I didn't read the Exif; Aperture Priority, ISO 400, shutter speed 1/1000 exposure on both ?
---------- Post added 04-29-15 at 04:10 PM ----------
I would send the camera back, I think something is wrong.
04-29-2015, 07:32 PM   #7
GryphonPhotoCat's Avatar
I would do some test shots of different things that will let you put your shutter through it's paces... Just encase.
test each setting for overall and see if it's working the way you expect it to...
For example I had a problem with my K-01 were the shutter was going bad. I took pictures of something like a light bulb at 1/4000th of a second and found out that any thing over 250th or so wasn't working... the shutter was sticking and not responding correctly.
05-05-2015, 07:17 PM   #8
royden's Avatar
Posting so I can follow this thread as I have that combo. I did not have this problem.
05-06-2015, 02:24 PM   #9
After 1000 photos - i can say problem is gone. I guess juice on front element was problem. Weird. I will post if it happens again.
camera, drink, iso, pentax help, photography, troubleshooting
Guidance on a K5-II or K5-IIs and lenses Kubikle Free Pentax K-5 5 12-22-2013 01:07 AM
pentax da 16-45 vs 16-50 da* for K5? gf1 Pentax SLR Lens Discussion 18 11-16-2013 10:14 AM
What general purpose lens for K5 (16-45, 16-50, 17-70, 18-135)?) miho Pentax SLR Lens Discussion 25 08-22-2011 04:13 AM
For Sale - Sold: Pentax K5 and DA 16-45 $1250 (US) narichey81 Sold Items 2 05-16-2011 11:58 AM
All times are GMT -7. The time now is 11:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
