04-30-2015, 06:36 AM   #1
A question regarding the charger for the Pentax K-5
Hi Folks
I have a question regarding the battery charger for the Pentax K-5.
I am in the process of buying a K-5 from Japan and I was wondering
if the charger is multi voltage or will I need a new charger to use here
in Australia? I am trying to avoid having the camera arrive and then
having to send off for a charger - if I can find out now I can order one
so it will be here at the same time as the camera
Also, I can get a K-5 II for around $200 Aus more than the K-5. Should I?
I grabbed Two lenses off ebay 16-45mm & 55-300mm so I can't change
my mind - I NEED a Pentax
all the best
Doug
04-30-2015, 07:22 AM   #2
Rimfiredude's Avatar
The K5 II is the most undesirable of the 3. If it were a K5 IIS it might be worth it. Stick with the K5.
04-30-2015, 07:31 AM   #3
kh1234567890's Avatar
QuoteOriginally posted by Rimfiredude Quote
That's rubbish. The only difference between the K-5ii and the K-5iis is the AA filter which in practice gives a debatable very small improvement in IQ. The AF is much better on the K-5ii(s) as is the LCD screen.
04-30-2015, 07:49 AM   #4
hcc
hcc's Avatar
Normally the battery charger is 110/220V for the K-01/K-5/K-3. You will only need to change the plug in Oz.
Have you considered a K-30/K-50? They are now quite cheap. Otherwise I would go for a K-5ii/K-5iis because of the better AF over the K-5.
04-30-2015, 08:47 AM   #5
sterretje's Avatar
Good lenses; add the K5/II.
K5 has artificial light focusing issues (from experience) when using PDAF focusing.
04-30-2015, 09:00 AM   #6
jatrax's Avatar
Charger that came with mine is multi voltage, just need a different plug.
Get the k-5II or k-5IIs if possible, much improved over the k-5. I've used both and the improvement in AF alone is worth the extra.
04-30-2015, 09:07 AM   #7
Yes, it should say so on the back of the charger. Available plug adapters should work.
05-05-2015, 02:17 AM   #8
Thanks for the quick replies everyone, I ended up buying a K5 in Australia
camera, charger, k-5, pentax, pentax help, photography, question, troubleshooting
Question regarding the mount shield lens StigVidar Pentax Q 6 05-27-2015 02:24 PM
Finally ordered K-5 , a question regarding lenses , please help kamisu Pentax SLR Lens Discussion 19 03-21-2012 09:19 AM
A brief interview with Pentax UK manager from the BJP - Regarding the K-01 crabclawhands Pentax K-01 12 02-02-2012 01:10 PM
My first K-r issue, regarding battery charger, and a potential fix Philoslothical Pentax K-r 5 08-18-2011 05:26 AM
Question to the experts - regarding K-5 NR dexmus Pentax K-5 20 11-03-2010 10:36 AM
All times are GMT -7. The time now is 11:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
