04-30-2015, 06:36 AM   #1
Pentax K-x Card error
I have been offered a K-x to replace my K100d. On start up I get the "Memory card" error as described by dozens of posts on the net. I have tried all sorts of cards and batteries, etc. Formatting cards,etc. When holding down the Menu button on start up with the card with Ver 1.03 firmware, it shows the current ver. 1.01, and then the error msg. Any info will be welcome! Or shall I just forget about the K-X?
Thank you
Johann
04-30-2015, 07:59 AM   #2
jatrax's Avatar
It has been a long time since I had the k-x but it is possible it cannot handle newer SDXC cards. What type of card are you using with it? SD, SDHC or SDXC?
Also, make sure the SD card port door is completely closed.
Updating to the latest firmware would also be recommended. If I remember correctly there were a number of improvements with 1.03 but I don not remember if they included memory cards.
04-30-2015, 02:10 PM   #3
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Thread moved to proper area. Archives articles is not where this belonged.
04-30-2015, 02:14 PM   #4
Yes, the K-x can use a SDXC but only with the firmware update. You said you have the firmware on the memory card. Did you put the .bin file on that card and in the root directory, not in a folder on the card?
04-30-2015, 05:04 PM   #5
davidreilly3207's Avatar
QuoteOriginally posted by photolady95 Quote
Also, make sure you extract the file before placing on the root directory of the card. If it has .zip on the end, you have not extracted it. it must have .bin on the end.
04-30-2015, 05:29 PM   #6
echo in here.
04-30-2015, 07:51 PM   #7
K57XR's Avatar
QuoteOriginally posted by JohannMendelsohn Quote
If you don't mind me asking, putting aside firmware upgrade have you tried a memory card that is sure to work, something like a standard 2GB SD card and see if the error message persists? If the cards you've been trying are SDXC which are not supported by FW 1.01, this might be the reason for the error message. If you still get an error even with a non-SDXC card then I'm afraid it might be more than just firmware upgrade.
05-01-2015, 01:08 AM   #8
SD and SDHC only. Card door closed properly. As per my post: I insert card with Bin file but it does not SEE it
---------- Post added 05-01-15 at 10:10 AM ----------
Positive! It foes not see any card. Bin in root.
---------- Post added 05-01-15 at 10:12 AM ----------
QuoteOriginally posted by mdave13 Quote
I have done that. I have updated Firmware before on K100d as well as varius Canons
---------- Post added 05-01-15 at 10:17 AM ----------
QuoteOriginally posted by K57XR Quote
Yes, they all worked. It came with an old 512kb card used while it still worked. It then started give the error msg. This old card works on pc, mac, and other cameras. Sending a camera in to Pentax here in South Africa apparently takes months to get results, according to a dealer. Makes one think if it is worth while to persue this avenue or just scrap it. Thanks for all the replies. Let's try a bit longer!
---------- Post added 05-01-15 at 10:18 AM ----------
05-01-2015, 05:05 AM   #9
Did you try to reset the camera back to default settings? It might not matter but to cover everything, that's what I would try to do and see if it helps. Sure can't hurt.
05-01-2015, 09:02 AM   #10
Try using a rocket blower on the card slot. A piece of dirt may be the cause. Also, do not trust the battery indicator as to charge level. Remove and charge overnight to insure a full charge. Many different and seemingly unrelated errors seem to crop up with low battery charge.
If the 512 card works in the computer, try reformatting with fat32 it in computer and leaving it blank for testing in camera.
If cards that work in your other camera wont work in this one, your only solution may be to send for servicing.
05-01-2015, 10:11 AM   #11
K-x uses AA batteries, not the single Pentax/Wasabi Li109 or other. But you should still make sure the batteries are fully charged, and probably shouldn't be using standard alkaline ones either. My K100d wouldn't even power up with standard alkaline batteries.
bin, camera, card, cards, directory, error, file, firmware, k-x, memory, memory card, pentax help, pentax k-x card, photography, post, root, sd, sdhc, sdxc, troubleshooting, ver
Memory Card Error On K-5 zeda3000 Pentax K-5 16 06-01-2014 04:51 AM
Pentax K-3 card error with Samsung SDHC horses Troubleshooting and Beginner Help 3 05-21-2014 06:08 AM
K-7 giving memory card full error Rosz Visitors' Center 4 02-24-2014 03:58 PM
K-30 and UHS1 card "Memory Card Error" pavanbabut Troubleshooting and Beginner Help 18 12-29-2013 05:10 PM
Pentax k-x '' card error '' message crossing Pentax DSLR Discussion 4 01-13-2010 01:17 PM
All times are GMT -7. The time now is 06:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
