12-08-2015, 05:14 AM   #16
patrick9's Avatar
QuoteOriginally posted by jeannehere Quote
***putting in foam pieces did not keep the battery in place or camera on
When my battery lug broke in my K30, the camera still worked even without a spacer added to the battery compartment. I had mine repaired simply because I still had a month of warranty left.
Note ......I purchased mine from Canada so I had a 2 year warranty.
Is your battery charged and still good?
12-09-2015, 01:50 PM   #17
Quartermaster James's Avatar
Does it work with AA batteries and the adapter?
12-10-2015, 01:42 PM   #18
QuoteOriginally posted by Quartermaster James Quote
I will check if I have the AA adapter . I purchased many accessories and believe that's one.
12-10-2015, 07:03 PM   #19
Alnjpn's Avatar
I have been using mine without the retainer for a while now; no foam, just held in place with the battery door. I haven't had any problems. It should work even without the retainer, so keep trying.
02-15-2017, 03:24 PM   #20
E-man's Avatar
I wonder if you could wedge a piece of paper or something into the battery compartment to hold the battery in place and avoid extra tension on the battery door. D-Li109 batteries, especially the generics fit pretty snug in the battery compartment already.
04-13-2017, 03:59 PM   #21
Mine broke today. Both AA batteries with the adapter as well as the original lithium battery still work though, and are held in by the battery door. Hope it holds up ok like this as I'm not going to repair it. I've never liked the way batteries are retained in the K30 and the battery door has always felt so cheap to me even from the first time I touched it.
04-19-2017, 07:45 PM   #22
Kozlok's Avatar
This thread resurrected from nowhere. I'll give an update...Mine broke back in 2015, camera still sees more or less daily use, still not a problem. I don't wedge anything in at all, just close the big door, and it's held the battery in fin for the last 2 years.
battery, camera, k30, pentax help, photography, question, retainer, troubleshooting
LCD screen on K30 is broken jcshellyg Troubleshooting and Beginner Help 3 09-14-2014 09:04 AM
Is it madness to be thinking about a K30 or K5 (as a K7 owner) Conqueror Pentax DSLR Discussion 28 07-07-2013 05:22 PM
K30 Firmware upgrade - Is it worth buying a 32gb card? Steven Chain Pentax K-30 & K-50 7 02-11-2013 04:56 PM
Pentax Super program Plus: Want to use it, is it broken? pcarfan Pentax Film SLR Discussion 12 06-28-2010 03:34 PM
anyone else had a problem with broken shutter button on the D-BG2 battery grip? sholtzma Pentax Camera and Field Accessories 4 07-06-2008 01:27 PM
All times are GMT -7. The time now is 06:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
