05-10-2015, 02:27 PM   #1
da 21mm ltd a bit of "give" or flex between the parts
Hi,
Handling my da 21 I've started to notice a fair bit of movement between the parts. Pushing the focusing ring sideways makes it move a fraction of a mm before it stops with a clicking sound. The filter thread (including the lens elements) can be moved in a similar way jogging back and forth producing clicking sounds as it stops at the most extreme position. Picking the lens up you can feel how something is moving.
I haven't noticed any degradation in image quality even if focussing is a bit hit and miss with my K5.
Thing is I can't remember if the lens always had this amount of flex or if has developed over time. Knowing that the smc da 21 has had a few disassembly issues I thought I'd check if other da21's are solid without 'give' or have a tiny amount of flex between the elements of the construction.
/Cheers
05-10-2015, 03:40 PM   #2
Alnjpn's Avatar
Hi, mine is exactly the same as this and has always been this way. Don't think it is anything to worry about
05-10-2015, 04:23 PM   #3
Caver's Avatar
QuoteOriginally posted by house Quote
Hi,
/Cheers
There are (probably several) threads about this, here is one where I've contributed recently:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/292282-ques...ed-owners.html
It seems that there are lenses (not just the 21) with similar "behaviour" - generally not affecting the IQ or the functionality.
05-10-2015, 04:57 PM   #4
Sandy Hancock's Avatar
A few of my limiteds (15, 21, 31 - all AIV) have developed a bit of wobble. It doesn't seem to have affected IQ at all. My 43 and 77 (both MIJ) and 35 (AIV) are fine.
05-13-2015, 11:06 AM   #5
Thanks for the info. Apologies for missing those threads.
amount, bit, camera, da, da 21mm ltd, da21 21mm limited, disassembly, elements, flex, lens, ltd a bit, movement, pentax help, photography, troubleshooting
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
which is better "DA 21MM F3.2AL Limited" or "SMCP-FA 20-35MM F4" ? Flame Angel Pentax SLR Lens Discussion 9 07-04-2013 08:10 AM
what happen if i shoot with the "back" of the film instead of the "front" ? aurele Film Processing, Scanning, and Darkroom 20 07-03-2013 08:21 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 05:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
