Originally posted by rafoarc Thanks Stavri. My thinking was that if I will not be able to fix it I might just use it as a manual lens, so knowing that manual focusing is not the best option with this lens helps. I guess that replacing the electronic board would have a similar cost to getting a properly working lens, so most probably I should forget about it...
I agree, this lens is just not manual-focus friendly (designed that way), as is the case with most F series lenses (expect the extreme-telephoto ones) The A 50/f1.4 is identical to the F and has better dampening, it's the best choice.
