05-15-2015, 05:30 PM   #1
Adaptall PK mount
Quick question: does this mount always stay stopped down when you move the aperture ring? It appears to be a real Tamron adapter but when it's on my 60-300 it's always stopped down. When I take the mount off the lens, it's fine.
This prevented a trade-in on the lens (which I'm sorta grateful for because I do like the lens and was just trying to save money on a new one =P) because despite the lens being functionally perfect without the mount, they wouldn't accept it without it. =P
Thanks!
05-15-2015, 07:09 PM   #2
You mean when it is off the camera, right? When it is mounted (to the camera) it should stay wide-open until the shutter snaps. However, when it is off the camera, the aperture should open and close as you turn the ring, yes. (Make sure you have both little tabs on the mount properly in their slots on the lens -- if they are not that will keep it from operating correctly.)
05-15-2015, 07:43 PM   #3
YQG
Nope, it does it on or off camera. It's not the body, because the store tried it on two other film bodies with the same result.
I just played around with it and discovered the problem, the arm to keep the aperture open was bent over too far and wasn't hitting the catch in the camera. TIL things. =)
Thanks for the verification and assisting in my discovery! Now I feel better.
05-15-2015, 08:50 PM   #4
Not a Number's Avatar
I seem to recall a post outlining proper procedures with this adapter that unless followed could result in damage as described.
05-16-2015, 04:33 AM   #5
Lowell Goudge's Avatar
QuoteOriginally posted by YQG Quote
Thanks!
The mount should behave like a K mount lens, it is stopped down to the set aperture until mounted
05-16-2015, 08:09 AM   #6
Nope...I own two and have been using this type adapter for over 30 years.
There is a proper procedure (set aperture to maximum opening before changing adapter), but that is required just to get the adapter to seat.
What he said...
Glad that the OP found the source of the problem. The PK adapters generally work well, but they lack a guard for the aperture actuator to help avoid the kind of damage that was described.
adaptall, adaptall pk, camera, lens, mount, pentax help, photography, pk, tamron, troubleshooting
For Sale - Sold: Tamron Adaptall PK and PK/A adapter (and freebie - Adaptall 2 80-210mm) kp0c Sold Items 10 11-08-2014 06:14 AM
For Sale - Sold: PK/A Adaptall-2 mount gabriel_bc Sold Items 2 06-01-2014 11:52 PM
For Sale - Sold: Tamron Adaptall PK/A Mount dave9t5 Sold Items 2 10-19-2013 07:18 PM
Tamron adaptall mount PK to PKA conversion? gjw297 Pentax SLR Lens Discussion 16 12-18-2010 03:30 PM
All times are GMT -7. The time now is 05:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
