05-16-2015, 01:31 PM   #1
Metz 58 v1 will not fire
Hi,
I have hardly used my flash in the past 1.5 yrs and now it will not fire even when I push the green lit button. All other functions/controls work, has anyone else had the problem, and is it worth fixing?
thanks for the help in advance!
05-16-2015, 02:57 PM   #2
Same Problem
I am having the same problem with my Metz 58 v1. I don't know what's going on, and whether it is a Pentax communication issue or a more general malfunction. I have no suggestions as nothing I've done has worked.
05-16-2015, 07:51 PM   #3
I have had a problem with flashes not firing in the past.
Here are the two things I have done in the past and has always seemed to work.
1 Make sure your batteries are fully charged. I have found that sometimes if you haven't used a flash in awhile, partially charged batteries don't have the power to "wake" the flash up.
2 Pull the batteries out and use either a pencil eraser or a light cleaner on a q-tip to clean all the contacts on the flash. Sometimes a light oxidation has built up not allowing the full charge into the flash.
05-16-2015, 10:47 PM   #4
sterretje's Avatar
May we assume that the flash-ready indicator on the flash indicates that it is charged?
QuoteOriginally posted by Hiroshi Quote
Ask Metz for a quote. I think it will be cheaper than a new one.
camera, fire, pentax help, photography, troubleshooting
? Re Metz 58-AF2 not registering lenses ... kenhreed Troubleshooting and Beginner Help 4 07-03-2014 08:57 AM
K5 battery depletion message/shutter will not fire Scenesaver Pentax K-5 8 01-26-2014 08:09 AM
Cactus v4 triggers, Pentax K20D and Metz 58 won't fire. luke_sheff Flashes, Lighting, and Studio 5 03-16-2010 12:05 AM
Metz 58 wireless not working? Metz 48 works great? Ideas? ksignorini Flashes, Lighting, and Studio 6 02-07-2010 05:33 PM
All times are GMT -7. The time now is 03:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
