Originally posted by peacockblue I'm new to the dSLR though I've used a Spotmatic for 40 years. Is there a trick to getting the K50 to behave like the totally manual Spotmatic?
The only trick is to mount a K-mount lens that lacks the "A" contacts on the base.* In that case, the camera will be pretty much limited to M mode with stop-down metering using the green button. Metering will be center-weighted averaging instead of the Spotmatic's not-so-center-weighted averaging, but the experience is close enough. The user experience is about the same. Welcome to 1971!
(Learned on stop-down metered M42 cameras and currently own five such bodies...not counting the dSLR)
* There is a little bit more, of course. Aperture ring much be enabled in the menu settings. Also good to note is that lens having both an aperture ring and "A" contacts may also be used in primitive mode if the aperture ring is taken off the "A" position.
