06-11-2015, 02:00 AM   #1
Pentax AF360FGZ II Flash won't charge
Hello,
I recently bought the Pentax AF360FGZ II camera flash. It worked for about one hours but then it started to produce a high-pitched sound and stopped charging the flash. It displayed the message "lo bat".
I then changed the batteries to a fresh set and the camera flash continues to make the same sound and after a few seconds displays the same message "lo bat".
Anyone know if I've done something wrong, or is the new flash just broken?
06-11-2015, 04:19 AM   #2
max_pyne's Avatar
rechargeable bats or normal ones?
06-11-2015, 04:26 AM   #3
aleonx3's Avatar
rechargeable batteries such as Eneloop (NiMH) are better suited for flash than ordinary alkaline batteries, which ones are you using?
06-11-2015, 04:31 AM   #4
max_pyne's Avatar
QuoteOriginally posted by aleonx3 Quote
only if they are still good... they will loose their capacity over time...
06-11-2015, 06:33 AM   #5
QuoteOriginally posted by max_pyne Quote
better loose their capacity over time (eneloop at least 1000x times charge) than use normal battery and dumb after out of power, make more waste and no good for environment
PS: go green a bit
06-11-2015, 06:41 AM   #6
Hi folks,
Thanks for coming back to me on this issue.
I used Eneloop pro batteries - fully charged. I then used Duracell 2000mah batteries and the problem persisted.
06-11-2015, 06:53 AM   #7
max_pyne's Avatar
QuoteOriginally posted by mixberry Quote
better loose their capacity over time (eneloop at least 1000x times charge) than use normal battery and dumb after out of power, make more waste and no good for environment PS: go green a bit
:-) i just wanted to say that it could be faulty batteries... :-)
even though they are rated at 1000x they can fail before that, depended on the charger and other criteria...
i had that with different types of batteries (especially ansmann: some of them are just dead on will not recharge...)
06-11-2015, 07:45 AM   #8
AquaDome's Avatar
Rechargeable batteries supply a lower voltage than Alkaline batteries. No matter what the battery manufacturer claims, devices which expect 6 volts will underperform at 4.8 volts.
Purchase name-brand Alkaline batteries from a local source and pay full price. Duracell AA batteries are one of the MOST counterfeited items available for sale on the internet.
06-11-2015, 08:08 AM   #9
Thanks for the info about the rechargeable batteries.
I'll buy a new set of Duracells on my walk home.
I'll let you all know how I get on.
Thanks.
06-11-2015, 11:10 AM   #10
aleonx3's Avatar
QuoteOriginally posted by davidlpower Quote
Thanks.
I would stay away from alkaline batteries if I were you... they discharge at full power and your flash will heat up quickly.
OTOH, do you have another way to test if the batteries are good before putting in the flash? Or you could have a defective flash unfortunately.
06-11-2015, 01:09 PM   #11
If you are using the flash at full output, it will use your batteries up more quickly than not, I just wanted to mention. For example, you could set your flash at 2/3, 1/2, or 1/3, and if you find it accomodating, it will use less power than a higher output. I have the AF360fgz, not the II, and it has those options, I am assuming the II version is similar if not the same.
06-12-2015, 01:07 AM   #12
New batteries and the camera flash still wont charge.
I am starting to think the camera flash is broken.
06-12-2015, 08:21 AM   #13
Something you might want to check is if the contact mount (shoe foot) of the flash (which attaches to camera) is attached correctly and if it is physically not damaged. Also you may want to use some basic settings with the flash off camera and test it by using the test button on the flash head. If it does flash off camera and the shoe foot appears undamaged, you my want to try it on the camera again, but make sure to use the most basic of camera settings. If it does not work then, if you can try it on another Pentax camera or try another Pentax flash on your camera, you may want to do that. If no success is found in those tests, if you have a Pentax warranty, contact customer service and ask what your next step should be. Or if you are within a return policy period of the seller of the product, you may want to request a return for refund or replacement.
06-12-2015, 11:30 AM   #14
QuoteOriginally posted by C_Jones Quote
Thanks for your advice C_Jones. The flash doesn't work on or off camera. The test button never lights up. The flash is simply dead. I'll return it to the seller and try get a replacement.
06-12-2015, 01:24 PM   #15
As I mentioned, if you are a recent buyer you should have the alternative provided by the seller to get the replacement. You shouldn't have a problem.
If you ever have a problem with Pentax equipment that you have purchased that is under warranty, or just need help and the seller cannot help you, 800 877-0155 is the Pentax customer service number. I have always been given appropriate assistance when I have called. When you buy, always verify that the seller is a Pentax authorized dealer also, for a valid warranty.
I am glad I may have been of help. You are welcome.
af360fgz, af360fgz ii flash, camera, flash, ii, message, pentax, pentax af360fgz ii, pentax help, photography, sound, troubleshooting
For Sale - Sold: Pentax: 12-24mm F4 Ultra Wide Lens & AF360FGZ II Flash kraigg007 Sold Items 14 03-12-2014 08:23 PM
k-30 Battery won't take a charge? ccrookston Troubleshooting and Beginner Help 5 08-06-2013 06:33 AM
AF-360fgz made popping sound, now won't charge mangeh Flashes, Lighting, and Studio 3 03-02-2012 12:38 AM
AF360FGZ won't flash in wireless mode thatguyyoulove Flashes, Lighting, and Studio 16 10-19-2010 05:08 AM
my 360 fgz won't charge up... Lanfriendly Pentax Camera and Field Accessories 2 07-07-2008 07:18 AM
All times are GMT -7. The time now is 01:52 AM. | See also: NikonForums.com, part of our network of photo forums!
