06-12-2015, 01:42 AM   #1
help cheap m42 adapter stuck on k-x
i always use the m42 adapter like this and never have problems but i purchased other cheap and never used, one day i clean the camera and forgot to mount the right adapter, my brother take the camera today to shoot in the college a event (he use the camera sometimes and know how to and know i only use manual lenses) but i never say to him i not use that cheap adapter and he grab the cheap adapter and mount it on the camera, he shoot normally when he back i see it that and try to unmount but i dont know what he do but i cant.
I try everything i dont know what to do t.t
i attach a image of the camera and adapter and sorry for my english i hope all can understand u.u
06-12-2015, 01:47 AM   #2
manntax's Avatar
Get some rubber or wear a latex glove and putting pressure on the surface try and rotate it back with lens release pin depressed at the same time. It should come out with some elbow grease applied
06-12-2015, 04:07 AM   #3
Na Horuk's Avatar
This thread might help, but it involves some "surgery":
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/167741-m...-solution.html
First try to hold the lens release button on camera, then move adapter to where it should come out and wiggle it out. Don't push down on the adapter, only spin it
06-12-2015, 08:12 AM   #4
Not a Number's Avatar
Removing the lens mount will be difficult since the flange covers the screws. You should be able to grip the ring on the knurled part while wearing a rubber glove and twisting it off while depressing the lens release button. Try it with pushing the ring towards the body. Try it while pushing the ring towards the body. You could probably put your thumb on the inside of the ring but be careful of the mirror, focusing screen and power zoom contacts.
More extreme options would be to cover over the opening and drill a couple of holes in the flange or inner flange so you can turn the adapter with a lens spanner wrench. I would use a drill press so you can accurately control the depth of the drill holes.
06-12-2015, 09:57 AM   #5
QuoteOriginally posted by manntax Quote
Yes, use rubber gloves and no, don't apply downward pressure. That style adapter has no retaining spring and should turn turn out properly with the release button depressed.
...You should be able to grip the ring on the knurled part while wearing a rubber glove and twisting it off while depressing the lens release button. Try it with pushing the ring towards the body. Try it while pushing the ring towards the body. You could probably put your thumb on the inside of the ring but be careful of the mirror, focusing screen and power zoom contacts...
Putting a finger on the inside surface will definitely help, though I am still dubious about putting downward pressure on the adapter.
Cutting the adapter out with a Dremel too is a drastic last resort and requires a steady hand and care to keep the metal shards out of the body.
06-12-2015, 11:40 AM   #6
manntax's Avatar
Thanks for clarifying - obviously by saying putting pressure I meant to ensure the grip is good and friction will do the rest while turning. SO the pressure needs to be applied, but very balanced just so the rubber wont slip.
06-12-2015, 06:44 PM - 1 Like   #7
i do it guys u.u i use a plier (alicate we called her in that way XD) i grab the adapter border and make enough pres (like superman XD) and my brother hold the camera until the adapter go out *o* ty to all for respond and help <3
adapter, camera, dont, m42, m42 adapter, pentax help, photography, troubleshooting
M37 to M42 adapter stuck on lens .a.t. Troubleshooting and Beginner Help 10 07-09-2013 11:32 PM
M42 Adapter stuck on M42 lenses glee46 Troubleshooting and Beginner Help 31 11-29-2011 05:16 AM
Help! m42 adapter stuck on camera ADHWJC Pentax SLR Lens Discussion 8 09-23-2010 12:23 PM
Please Help! - M42 adapter stuck (not the leaf spring thing) countzero Pentax DSLR Discussion 17 12-22-2009 08:44 AM
HELP! M42 adapter stuck on lens! figmental1978 Pentax Camera and Field Accessories 2 12-27-2007 05:44 AM
All times are GMT -7. The time now is 04:27 AM. | See also: NikonForums.com, part of our network of photo forums!
