06-12-2015, 03:12 PM   #1
Pentax Program Plus stuck rewind
Hi everyone,
I have a Pentax Program Plus, 35mm film camera. I recently found this camera and used it once, and now it won't let me load another roll of film in it. I rewound the first roll I used in it and ejected it, but now the rewind button seems to be stuck pressed in, the film advance lever is stuck and won't pull back in order to load the film. I'm not sure if putting some grease in it around the button will help since it's so old and barely used, or if my camera is just done. Any suggestions? Thanks!
06-12-2015, 03:42 PM - 1 Like   #2
Not a Number's Avatar
The shutter is cocked. Put some batteries in it, turn it on and press the shutter release. The rewind button will reset when you operate the film advance lever. If it doesn't turn on after cleaning the terminals with fresh batteries then it needs servicing.
06-13-2015, 12:15 AM   #3
That did the trick! Thank you, I can't believe I didn't think of the batteries causing that. Thanks again!
50mm, button, camera, film, help, load, pentax, pentax help, pentax program, photography, program, program +, program plus, program plus body, roll, troubleshooting
Super Program Rewind Funky Jamey777 Pentax Film SLR Discussion 4 12-04-2013 03:29 PM
Help: Program Plus Stuck Mirror CGJung Pentax Film SLR Discussion 17 02-11-2013 10:05 PM
mirror stuck up on a program plus newpentaxman Pentax Film SLR Discussion 9 07-01-2011 08:43 PM
need help! black program plus shutter stuck!! newpentaxman Pentax Film SLR Discussion 19 03-21-2011 12:02 PM
Stuck dial on my Program Plus filmamigo Pentax Film SLR Discussion 4 03-14-2011 05:44 AM
All times are GMT -7. The time now is 01:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
