Thank you for your answers guys. So I tried to leave it outside, hoping that it will relocate itself, but for no luck. GPS is still turned on. It's just stuck there with the red searching signal icon. Removed the battery, did it again for 30+ minutes to no avail. I also tried to re-flash the firmware with the same version (there is only 1.00 out so far) and it got stuck on NOW LOADING screen. I thought I bricked it, prayed, took out the battery and put it back, turned on - and the camera is fine. Except nothing has changed. I would like to try debug menu, but I have no idea how to find out the first number of the two.... that 0077xxx.xxx Can you help me there? I can make 1000 files with a different extensions .000 - .999
, but the first part of the filename is the problem... If this won't help, then I guess I'll need to send it back to JApan, because Ian R. Little company has a statement on it's web that if I did not buy it through them, they can't provide any kind of service or repair. :/
