Originally posted by cyclone3d Definitely the sensor. Have you tried the dust removal function on the camera?
Do you have automatic dust removal enabled?
Try pointing the camera vertically down and then use the dust removal function multiple times in a row.
If the dust removal function doesn't help, then it needs to be serviced.
How exactly does one get a lot of dust on the mirror or anything else inside the body in the first place?
I haven't tried it... I did enable the automatic dust removal, I will take some photos tomorrow to see whether or not it worked. And, I don't know how all that dust got inside the body. Perhaps, when I was switching lens. But honestly, this is just sad because this camera is brand new. Barely used it for 2 months.
---------- Post added 06-14-15 at 03:10 PM ----------
Originally posted by Na Horuk Nope! The mirror does not affect the photo! You can have a mirror sprayed with red paint and it will not affect the image, as long as the mirror moves out of the way correctly.
You see, when a shot is taken, the mirror moves out of the way, then the shutter courtain opens, exposing the sensor for the shutter speed number, and then the shutter closes and the mirror closes after it.
Those spots you see are dust spots on the actual sensor. You can turn on the dust removal function in the camera (many people set it up to automatically do that on shut down. These options are in the Menu, feel free to check the manual).
The other thing you can do is use the sensor cleaning function and use a rocket blower to blow off the dust, being careful not to actually touch the sensor. There are many threads and tutorials about sensor cleaning btw, just search these forums or the net. There are other tools for sensor cleaning, but the air blower should be enough to begin. Some shops offer this as a service. In some countries you even get a free sensor cleaning as part of the warranty (or extended warranty).
Edit: One more thing. Similar spots can be caused by dust on the back of the lens, but that is more rare. Anyway, you can check that as well, but be careful, as the back of the lens is more sensitive than the front. Generally its advisable to use those air blowers to remove dust without touching anything.
Thank you SO much for taking the time to explain all this to me, I really appreciate your help.
Just to get things straight - dust on the mirror, focusing screen or on the pentaprism DOES NOT affect the image in any way? And if there is any dust inside the body, it CANNOT spread to the sensor itself?
I set the camera to automatically remove dust upon shut down, however, I am very confused about the recommendation in the previous post - pointing the camera vertically down and enabling this function. Any thoughts on this?
I will look into sensor cleaning as in professional cleaning but I know that there are no official Pentax shops where I live (Paris, France). And I am reluctant to send the camera to the service center that Pentax partnered with because well, I am scared that shipping would damage the camera.
And... sigh... I used a Lenspen on the back of the lens as well... Honestly, I feel so ashamed about the lack of my knowledge on camera cleaning. I guess I should have really taken time to research this topic... again, thank you so much!
