Originally posted by Bonobo I have the small version so I don't encounter that problem. You're going to have to give us more information though on what exactly you're doing so we can help. Maybe attach a picture of the setup how you're trying to use it. Was the flash new or used?
Is your flash pointed straight up into the bender? Or are you trying to point the flash somewhere at an angle between 0 and 90 degrees? It should be fine if the flash is at either a purely horizontal or vertical angle. If it is pulling the flash head from a vertical position down, then that'd be potentially cause for concern (not insurmountable). If not, I'd suggest searching youtube for 'flash bender'. There's a plethora of technique videos that may be more helpful than anything else.
The version of flashbender I have is the large one with diffuser. The flash head is angled perfectly vertically and I am not trying to adjust the angle of it in anyway. What I'm referring to is that sometimes when I lean my body forward when I take shots. I do not really lean that much but a slight forward of my body (hence the slight change of the angle of the camera) will trigger the flash head sliding down. I am also holding the camera in default landscape mode..
Besides, I suppose the AF540FGZ II should have a lock on absolutely any stops/angle.
