Originally posted by outcast86 I just purchase a vello freewave wireless shutter release remote and to my suprise it won't autofocus on my k-5iis. I tried it will my old k-7 and it works just fine. I also tried different lenses on both cameras and it refuses to focus on my k-5iis regardles of the lens, but still worka fine witht the k-7( same lenses used on both). Any idea what might be the problem? Any help will be much appreciated.
Thank you
Works okay on both of my K5IIs bodies and an older K5. It does require Record Menu 5, Button Customization, Shutter Button Half Press set to Enable AF.
You may have disabled it for exclusive use of the rear AF button. That really isn't necessary, you can have both enabled. I've been using rear AF so long, can't do it any other way.
