Originally posted by pishta The ELNA caps in the link are rated for 1000 hours.
That is at the rated max temperature. The lifetime typically doubles for every 10C drop in operating temperature. So you should get a few years out of it at room temperature before the electrolyte dries out/decomposes. It is very inconsiderate of manufacturers to make a limited life component such as this effectively non-replaceable, in order to sell more camera bodies.
As much as these caps are touted to be the solution to all of mankind's power storage problems the fact is that they are an evolutionary dead end since being a capacitor the output voltage drops on discharge (as opposed to batteries where the output voltage stays more or less constant during discharge), making it difficult to recover all the energy that you'd put in. But I digress (I used to dabble in electrochemistry for a living) ...
