06-29-2015, 11:51 AM   #16
UncleVanya's Avatar
QuoteOriginally posted by patrick9 Quote
I am glad you got it off. The Ricoh pin drops into the screw drive hole on the Pentax camera mount. I have seen where some have been able to get the lens to turn by switching from MF to AF and back while trying to remove the lens. It would be better to just remove the pin from the lens
On a Pentax camera Film or Digital the pin serves no purpose. Only on older Ricoh Film cameras does it have any relevance.
06-29-2015, 07:23 PM - 1 Like   #17
Only on Ricoh and Sears camera bodies having programmed exposure automation to be more precise. Those date from the mid-1980s and newer. Removing the pin is not a big deal unless you have one of those cameras.
06-30-2015, 07:18 AM   #18
UncleVanya's Avatar
Thanks Steve - I forgot the Sears one's.
06-30-2015, 09:37 AM   #19
Mount is held on by 4-5 screws. Pin is spring loaded, just remove lens mount and pull the pin out. Switching from manual to autofocus physically moves the focus drive screw in and out of mount. If the Ricoh pin is under little tension, and is caught in AF drive, you might be able to cycle the AF switch while gently turning the lens as directed in earlier post.
camera, lens, pentax help, photography, troubleshooting
Pentax K2000 breakdown to sensor level brewmaster15 Pentax DSLR Discussion 17 07-08-2015 10:13 PM
I want to get a DSLR....but having a pushback on Pentax LuisLimbert Pentax DSLR Discussion 46 01-31-2014 03:40 PM
Having a little trouble with a new (to me) lens T.P.S. Pentax SLR Lens Discussion 12 07-21-2013 11:08 PM
Please explain AA filter and consequences of having/not having it. jpzk Pentax DSLR Discussion 49 09-13-2012 12:57 AM
Cost breakdown K7 cupic Pentax DSLR Discussion 8 06-25-2009 07:04 AM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, part of our network of photo forums!
