07-01-2015, 07:15 AM   #16
According to the K10D service manual to remove the main board you have to unsolder 23 connection and disonnect 3 flex cables (two 2 point and one 3 point connector) and 3 glued screws hold the SR - CCD module. A 35mm block gauge and he service adjustment software is needed to adjust the SR module.
I stand corrected, proof on the K10 that you need a gauge to align the SR-CCD..wait, I though these had a CMOS? :-) The glue is most likely for the SR function so as not to vibrate the assembly loose. Thats about the same amount of connectors on a K-x, 5 at each corner and 2 powers to the middle. I'd still give it a shot, not worth beans as it is.
07-01-2015, 07:59 AM   #17
Not a Number's Avatar
The service manual refers to the assembly as SR/CCD.
07-01-2015, 11:03 AM   #18
With the 10MP sensor used in the K10D, K200D, and K-m (K2000) the Pentax CCD era ended.
The 14MP Samsung sensor of the K20D and K-7, and the 12MP Sony sensor of the K-x and K-r started the Pentax CMOS era.
07-01-2015, 09:58 PM   #19
Good to know. Ill refer to the correct nomenclature from now on. For the sake of curiosity, have you (the thread starter) dared to open the case? This could be as simple as a disturbed ribbon cable as there are 2 going to the SR/CCD. Perhaps one is dedicated to the sensor and one is dedicated to the Shake Reduction operation. I diagnosed a K-x "No LCD" issue to a detached ribbon cable. The plastic socket actually split on the end reducing its ability to hold the ribbon cable. The 2 are push on with no mechanical retention mechanisms (no clips or levers).
07-02-2015, 07:14 AM   #20
QuoteOriginally posted by pishta Quote
Nope, CCD. CMOS came on the K20D.
07-06-2015, 04:30 PM   #21
Pauld's Avatar
Seriuosly, save yourself the headaches and buy a new body. The time and trouble to change the sensor on an almost 10 year old camera is not worth it when you can buy used k5's for around $300.
camera, dslr, k10, lens, photography, screen
Applying Custom Image Preset in K-3 After Taking Photo dcpropilot Pentax K-3 4 12-26-2014 07:28 AM
Blank White Screen After Taking Photo - K5 Jason_Batley Troubleshooting and Beginner Help 4 02-02-2014 03:17 PM
Little sound after taking a photo? loco Pentax K-30 & K-50 2 08-05-2012 06:44 PM
*ist ds won't play back after taking photo octoma Troubleshooting and Beginner Help 5 07-06-2012 05:26 AM
K7: Camera unresponsive after taking photo Javaslinger Pentax DSLR Discussion 5 11-04-2010 10:46 PM
All times are GMT -7. The time now is 09:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
