06-29-2015, 11:16 PM   #1
No WB; Flash, Drive Mode, etc. available
While using my K3 today I couldn't get to the WB; Flash, and Drive Mode menus. The menu screen would just stay blank when I pressed any of the Four-way controller buttons. The buttons and the screen worked for other purposes. Eventually I turned off the camera, and turned it back on. The menus worked okay then. Has anyone had this happen to them?
06-29-2015, 11:20 PM   #2
You're most likely in AF point SEL mode. Press and hold the AF point selection button (the one below and to the right of the 4-way pad) and then the 4-way controller should allow access to the normal sub-menus.
06-30-2015, 12:05 AM   #3
Oh, yeah I was fooling with that for the first time. Thanks!
06-30-2015, 02:49 AM   #4
rayallen's Avatar
Another instant solution in pentaxforums.com! Nice work, Adam.
07-01-2015, 06:40 PM   #5
Otis Memorial Pentaxian
This has caught me twice.
07-10-2015, 11:28 AM   #6
mcgregni's Avatar
And I've been caught out in playback mode as well, when the four -way controller takes you to mostly uncharted terrain (raw development options etc). I have to admit that one of the very few interface frustrations I ever experience with the K7 is flicking back in and out of playback mode, trying to get back to the status screen. Always seem to end up cycling through the blank screen and horizon indicator display when I don't want them!
There ... That's the only bad thing I'll ever say about the K7 😁
buttons, camera, drive, flash, menus, mode, pentax help, photography, screen, troubleshooting, wb
Manual mode no longer available on K-01 ckbboy Pentax K-01 8 11-26-2014 10:30 PM
Built-in flash "not available" with DA 10-17 etc., can someone confirm? asp1880 Pentax K-3 & K-3 II 6 06-20-2014 12:06 PM
K10D drive mode selection, and flash compensation trd300gt Pentax DSLR Discussion 4 04-11-2009 07:18 PM
Flash firing immediately on "2s delay" drive mode oguzgel Pentax DSLR Discussion 5 03-30-2008 01:20 PM
All times are GMT -7. The time now is 07:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
