06-30-2015, 12:46 PM   #1
Help! in Italy on vacation and K10 won't take picture with DAL 55-300
Help, I'm in Italy on vacation and my K10 won't take a picture with my DAL 55-300 Lens. I can manual focus the lense but when I press the buton it doesn't try to auto focus or take a picture. I have a DAL 18-55 that works just fine. Even on manual focus it won't take a picture. Any suggestions? I tried cleaning the contacts and resetting the camera but neither seem to work.
06-30-2015, 12:53 PM   #2
Stavri's Avatar
Are the aperture contacts working properly, do you get data on your f-stop and shutter? Make sure the option under Settings: "Using aperture ring" is set to 2. Permitted (it's a feature for manual focus lenses but it might affect modern lenses with bad contacts)
06-30-2015, 12:55 PM   #3
UncleVanya's Avatar
Do you use a battery grip?
Maybe disconnect it if you do?
06-30-2015, 01:05 PM   #4
Ok with more playing if I press the lense lock button and barely turn the lense off the AF indication switches to MF and it will take a manual focused picture. Is that a contact issue?
---------- Post added 06-30-15 at 01:07 PM ----------
I do get F-stop stop info but I don't get any shutter action when I press the button.
06-30-2015, 01:29 PM   #5
QuoteOriginally posted by TamaraE Quote
I own a K20, and it won't take a photo unless it can confirm focus (in AF mode). So I guess for some reason it can't communicate with the lens about the focus.
I would mount and unmount the lens at least 10-20 times, just to scrape off any possible dirt stuck to the contacts. Another option is to try to scratch the contacts with sandpaper/knife, to remove any possible dirt.
06-30-2015, 02:18 PM   #6
UncleVanya's Avatar
Per the web on the K10 both AFC and MF modes should allow you to fire the shutter without focus confirmation. But since MF isn't - I'm stumped.
06-30-2015, 04:21 PM   #7
Are you shooting at the extreme ends of the zoom range? I used to have that problem with my DA 18-250 shooting at the extreme long end, but if I backed the zoom off a hair the camera would fire. No idea what was causing it, but try it and see.
07-01-2015, 12:34 PM   #8
No it doesn't seem to matter what zoom range I use.
07-01-2015, 03:12 PM   #9
UncleVanya's Avatar
Find another Pentaxian and try the lens on their body?
07-01-2015, 03:24 PM   #10
Flip ALL the physical switches through their modes a few times (AF/MF, SR on/off, mode dial back and forth) -- it has been known to fix a problem once in a while if something is sort of stuck between modes. (especially AF/MF switch)
button, camera, focus, k10, lense, pentax help, photography, picture, press, troubleshooting, vacation
Camera won't autofocus or take a picture with pop up flash GabrielFFontes Pentax K-r 16 03-07-2012 05:39 PM
For Sale - Sold: K-x (White) with DAL18-55 and DAL 55-300 ecwoj Sold Items 5 01-08-2012 09:35 AM
Pentax ZX-L won't take picture pointed up? SuperAkuma Pentax Film SLR Discussion 3 03-15-2009 06:46 PM
Help -- Flashing AV sign won't let me take a picture bobafett Pentax DSLR Discussion 10 03-27-2008 06:28 PM
All times are GMT -7. The time now is 06:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
