Originally posted by cristianmiu i was reading that the AF adjustments apply only for pentax lenses. is it true?
On the K-x any AF adjustments in debug mode will be global. Per lens adjustment is not possible.
Originally posted by pishta Where is K-x debug menu for lens? AF adjustment...
Originally posted by cristianmiu @pishta, i hope this will help you
RiceHigh's instructions will give you access to the debug menu. Be aware that that is a dangerous place unless you are sure you know what you are doing. Playing with the AF adjustment is relatively safe, but other things accessible through Dev/Debug had potential to "brick" your camera.
