Originally posted by ctt Tks; yes I have read the manual& it is a lot to read. When I go into the drive mode; I can't see how to turn it off.
You don't turn it off, just change to single exposure mode. You can have only one 'drive mode' selected at a time. So to turn of bracketing, hit up arrow> select single exposure mode (all the way on the left). You might have to hit the up arrow to get out of bracketing options if you went there. Bracketing is a "drive mode" not an option.
The top menu in the drive selection mode has the main selections: single, multi and so on. If you select one and then hit down arrow you get more options on some of them. For bracketing you get options for the number of exposures and EV between exposures.
