07-15-2015, 02:46 PM   #1
RubyT's Avatar
weirdest film problem ever
Hello.
I had been carrying around an Ilford single-use camera for about 6 weeks, and I finished the roll and dropped it off today. The first eight frames I shot are there, as are the last three. In between are 16 identical frames of a pen and maybe the edge of a printer? I'm not sure, it doesn't look familiar to me. I honestly do not specifically recall what I shot in the middle of the roll, since it was just here a photo, there a photo over the course of several weeks. I know it wasn't that, though.
Of course I've had experience with overexposure and underexposure and frames not turning out, but I've never seen anything like this--a single image repeating, frame after frame, in the middle of a roll.
I did drop off another roll of film (shot in a PZ-1) at the same time, and it turned out fine.
Does anyone know what might've happened?
Thank you in advance for your help.
07-15-2015, 02:57 PM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by RubyT Quote
Disruption of the space/time continuum?
I suspect they got your film confused with someone else.
07-15-2015, 03:30 PM   #3
do you have any children or other little hands that would have used the camera and then put it back where you last had it? Seems to happen here a lot. My kids want to convince me some stranger is coming in the house using my camera and then putting it back, but I am not buying it.
07-15-2015, 03:37 PM   #4
RubyT's Avatar
I do, but they're 12 and the weirdest thing is that the image is identical in every frame--I'm not sure how that could even be possible since you have to advance the film manually in one of these little singe-use cameras. It seems like even the steadiest hands, advancing while still at eye level, would move at least a little and the frames would vary. The image is out of focus, and looks more like what you'd get if you tripped the shutter by mistake while getting the camera out.
I did call back and request to be contacted if someone else came in with negatives they didn't recognize, and of course they assured me that such a mix-up is impossible, only one roll can go through at a time, and so on and so forth.
07-15-2015, 06:34 PM   #5
Painter's Avatar
Person at the lab rewinding the film? Are they properly spaced? Any double exposure? Weird
07-15-2015, 07:05 PM   #6
narual's Avatar
Did you get the negatives back?
07-15-2015, 07:22 PM   #7
Not a Number's Avatar
Right, did you get the negatives back? Along the perforations there should be some information such as film type or number and usually frame numbers. If the info is there and don't match up then there is your evidence that the negatives got mixed up right there. Even if this information is missing you can check the spacing on the perforation holes near the cut edges of the strips. If those don't match up or the spacing changes there is more evidence of a mix up.
But if you have a strip with both images you took and the unfamiliar ones then that would mean they all came from your camera.
07-16-2015, 05:13 AM   #8
RubyT's Avatar
They did all say XP2, so I have to assume the same camera. I'm now wondering if the counter was off and maybe the roll wasn't actually finished--another tech called and said when that happens they shoot a few shots in the back to get the machine to read the roll (it has to have enough shots on it or something). This is seeming like the most probable thing (that fuzzy image does look like the back of the store).
camera, course, film, frame, frames, middle, pentax help, photo, photography, roll, shot, troubleshooting, weeks
What's the weirdest thing that's ever been in your camera bag? ASheffield General Talk 50 11-26-2013 05:11 AM
Strangest lens problem ever.... Pentax-M* 300/4 JohnBee Pentax SLR Lens Discussion 6 04-25-2012 12:28 PM
1st Problem ever on my K10D from new waddojohn Troubleshooting and Beginner Help 16 01-12-2011 05:02 AM
Pentax latest (last ever?) film camera? penties rider Welcomes and Introductions 8 12-12-2010 03:28 PM
Did Pentax ever made a WR film body? ismaelg Pentax Film SLR Discussion 6 03-27-2010 07:34 AM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
