07-16-2015, 10:30 PM   #1
Arca Swiss no-twist help for d-BG5
So simple question: does anyone know of a no-twist custom Arca Swiss type quick release plate for the BG5?
I was excited to have my battery grip arrive in the mail today and not shortly after astonished to see that Pentax has inexplicably redesigned the bottom of the grip to something much more convex then the flatter BG4.
This is strange is the grips are almost identical and this introduces several more pieces and seams to a presumably environmentally sealed object .I could not imagine the design necessity of this. It seems like a purely arbitrary decision. Nonetheless my no-twist plates for the BG4 will not work with the BG5.
This alarms me as I have become very dependent on the quick release plate. And as I recall it was almost impossible to find one created specifically for the BG4.
Thanks
07-16-2015, 11:32 PM   #2
max_pyne's Avatar
haven't seen anything out there... only the mestos but they are not responding and its not possible to order anything from them anymore... tried different ways....
07-17-2015, 05:57 AM   #3
What about a custom machine shop? Has anyone had one custom made?
I would almost rather alter the pins on my BG4.
That brings up an interesting option. Does anyone know if any of the aftermarket grips maintained the original bottom of the BG4 instead of this new rounded disaster.
Also, what happened to Mestos?
07-17-2015, 07:24 AM   #4
narual's Avatar
It wouldn't be so pretty, but you could just take some Sugru and mold something to prevent twisting. It cures to a fairly firm rubber, and it's pretty easy to scrape off if you don't like the result.
Mestos... who knows? Their website works fine, until you try to check out. I did some research and the problem is that they need to update their shopping cart software. But I can only assume that since their ordering hasn't worked for at least 6 months, the business is no longer active.
07-19-2015, 07:19 PM   #5
narual's Avatar
https://www.pentaxforums.com/forums/172-pentax-k-3/299746-k5ii-grip-k3ii-stopped-working.html
That might be of interest. Apparently the grips are compatible if you remove one of the guiding peg things.
arca, arca swiss, arca swiss no-twist, bg4, bg5, camera, d-bg5, grip, pentax help, photography, plate, qr plate, release, troubleshooting
Arca Swiss Quick Release Plate for K-3 w/grip HenrikDK Pentax K-3 7 07-19-2015 08:10 AM
arca-swiss plate for K-50? lightbox Pentax K-30 & K-50 8 04-15-2015 02:26 PM
Any Recommended Arca Swiss plate for Q-K adapter? stemked Pentax Q 5 01-25-2014 09:23 AM
Arca-Swiss QR plate for K-30 BensonW Pentax K-30 & K-50 7 07-28-2013 10:31 AM
Arca-swiss quick plate for K30 WA-surfer Pentax K-30 & K-50 4 04-28-2013 07:33 PM
All times are GMT -7. The time now is 06:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
