06-15-2008, 12:31 PM   #1
K200D newbie question for color tone.
Just brought K200D and tested today. It was a sunny day in the morning so the white balance set to DayLight. The picture was taken in the shadow, however, I found the skin tone is a little bit strange. Am I did something wrong?
Thanks.
PENTAX K200D  Photo
06-16-2008, 10:25 AM   #2
Ole
Ole's Avatar
Light in shade has another color temperature than out in the sun.
Try Auto white balance for a start, it usually does a good job in natural light.
Or look for a white balance setting for shade, there might be such a setting on your camera.
06-16-2008, 01:10 PM   #3
The daylight setting is for light shining directly on the subject. In this scene, there is strong green light both from light reflecting from the grass and also from light filtered throw the leaves, which are unaccounted for by the daylight setting. I would recommend shooting in auto white balance unless you see something weird in your photos.
06-16-2008, 07:50 PM   #4
Like other said, keep it auto white balance. The K200D does a great job with Auto WB.
About the only time I ever use a manual WB is when I'm shooting in some strange conditions, like mixed temperature flourescent and incandecent, etc.
Even then, it's easy enough to fix it using PP, so I'm auto WB aout 99.9% of the time
06-16-2008, 07:54 PM   #5
Thank you for all the replies. Now I found the problem.
I was playing with the RGB color settings and forgot to reset them to default before shooting. Now everything back to normall.
camera, k200d, pentax help, photography
Film color tone imitation chaplinlau Pentax DSLR Discussion 12 10-25-2010 08:57 PM
Skin color/tone correction Help Needed! jpzk Digital Processing, Software, and Printing 15 06-06-2010 07:56 PM
New K200D - terrible color JN99 Pentax DSLR Discussion 61 07-31-2008 07:01 AM
what *are* the new K20D/K200D tone curve options? mattdm Pentax DSLR Discussion 6 05-18-2008 01:56 PM
Dumb newbie color question Izzy Troubleshooting and Beginner Help 13 12-10-2006 11:43 AM
All times are GMT -7. The time now is 11:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
