HELP! My K-30 has 14,217 actuations. It's worked perfectly. Just now I was using a manual lens and things were working fine, but after a dozen shots, using the green button to meter started not to work. Then the battery died. Put in a new, fully charged battery and put on a DA 18-135 lens. The lens doesn't open. (I.e., it is very dark in the viewfinder. Completely dark when I tried Liveview.) Now the whole thing is acting funny. Sometimes it turns on, sometimes not. If it turns on, it sometimes won't turn off.
I have a K-x, and the aperture lever in the body seems to be fixed in a middle/bottom position. In this K-30, the aperture level is at the top position and can easily be moved up/down. So did something happen with the aperture lever?
I have also
asked for help in a K-30 thread, but I'm also asking here. There seems to be some talk about an "aperture control" issue with the K-30, but I can only find scattered references to what this is. Does it also affect the battery?
Thanks for any help. (I have a big trip planned for Sunday, so this is not good timing...)
The camera is 2 years and 1 month old. I did buy the Adorama extended 2 year warranty, so I still have coverage.
