07-24-2015, 01:21 AM   #1
K5II overexposure on modern lensens only
A weird problem with my k5II is that it tends to overexpose massively with my modern lenses, which are the kitlens, DA35/f 2.4 and a DA40/2.8 i borrowed. I almost exclusively shoot in munual mode using the green button to set exposure if i need it set quickly. Interestingly, it works great when i use pentax-M lenses or m42s, which makes me think its a software problem rather than a mechanical one. Any suggestions here, as for theres nothing but to guesstimate exposure time and aperture
Thanks,
Sander
07-24-2015, 03:45 AM   #2
set your aperture to f22 or higher and shutter to 1 second look into the lens and press the shutter button to see if the aperture is working
07-24-2015, 04:08 AM   #3
Lowell Goudge's Avatar
What is the level of over exposure? You should check the linearity of the mechanism. You can do this by setting aperture with the dial and letting the camera set shutter speed, and the measure the greyscale value at each setting. My tamron 28-75/2.8 has an error in aperture which leads gradually to a +1 stop over exposure when at F32. It's perfect at F2.8
camera, exposure, k5ii, k5ii overexposure, lenses, pentax help, photography, troubleshooting
Modern K-Mount Lenses on Film SLRs? Biro Pentax Film SLR Discussion 12 12-01-2014 06:02 PM
Total overexposure on Star Trail attempts Michael Piziak Pentax DSLR Discussion 10 06-02-2014 06:40 PM
Fujica on K5II ? orionschwert Pentax SLR Lens Discussion 4 01-14-2014 07:52 PM
Modern flash on old pentax K2 SRJM Flashes, Lighting, and Studio 4 10-04-2013 11:39 AM
Overexposure on snow kluvi Pentax K-5 30 02-25-2012 05:18 PM
All times are GMT -7. The time now is 10:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
