Originally posted by Zerv Thank you for confirming, UV. I appreciate it.
May I ask you a few questions about using the Eye-Fi?
Could you tell me if you have any experience with using it with an iPhone and/or an iPad?
Is it easy to do selected transfers of JPEGs to a device? Or is it kind of a hassle where you have to go through a bunch of menus on either the phone and/or the camera to connect them together each time you want to transfer?
In real life usage, does it drain the battery intolerably? Does the card heat up as I've read reports of?
Is it reliable or have you had any corruption / errors with image files?
Any other thoughts or experiences with the Eye-Fi would be helpful. Thanks again!
I have an EyeFi Mobi that I have used with my K-r and my new K-3.
From the iPhone side, there's no control over what happens. You run through the initial setup, which installs a certificate in your phone. When you want to download photos, you open your Settings app and connect to the EyeFi's network. Then you open the EyeFi app and the photos download.
With the K-r, the card controls which photos get transferred. As a photo is sent, it is "marked" so that it will not get sent again. This can be problematic if you have multiple devices.
With the K-3, there is built-in EyeFi support, so the options are much better. You can transfer only one photo, several of your choice, an entire directory, etc. You can also reset the counter to mark all photos as unsent.
Then, you open the app, and the selected photos begin transferring.
With the dual slots on the K-3, this is really great. I shoot with a 32GB card in slot 1, and an 8GB EyeFi Mobi in slot 2. I write RAW files to the 32 and (XS) 2MP JPGs to the EyeFi. After an event, I transfer all the photos to my device, I might post a couple to Instagram, or if there are photos of friends and family, I can easily send them using any number of methods.
I haven't had any issues with the card heating up, or corrupt images, or massive battery drain. But I've only had the card for a few weeks.
