Originally posted by slr_neophyte I ran into some frustrating issues today with focusing and sharpness. Unfortunately I deleted the photos so am not attaching any samples for reference. I was using my K-5 II, with the DA 55-300. I was about 30-40 meters away from my subject (a seagull on a post in the ocean). My lens was at maximum zoom (300mm), shutter speed was 1/4000 (I think), and aperture was 5.6. I used a tripod for maximum stability, set the self timer so I would not have to touch the camera, and regardless of how many shots I tried the subject was still slightly out of focus (not tack sharp). I'm just wondering if this is a problem with the lens? Something I am doing wrong? Or, could it be the slight wind that existed? I was doing my best to shelter my camera from the wind during the shots. I'm using a pretty good tripod (Sirui T-025X).
Any thoughts / advice is appreciated. Thanks!
Just a suggestion. TAV mode, F10 - F13, 320 Shutter speed, Continuous AF mode, Center AF Point mode, Spot Metering mode, light (minor) adjustment with EV if needed, and handheld. If shooting something like a bird in flight (ex. Seagull), TAV mode, 1000 Shutter speed, F8, no EV if good light, to avoid possible underside shadow +3 EV if desired, and handheld.
