Originally posted by pathdoc I have heard this elsewhere and would like to know why this is the case.
My theory would be that any minor flaws in the lenses (usually as a result of age) won't show as clearly as on the newer sensors.
For reference I use an *istDS, much the same as the D.
Pretty much all my lenses are the A series (auto aperture, manual focus) and they all work great with the camera.
If you have a tight budget these lenses are great value, but obviously lack autofocus.
for Autofocus I would look at the F series, just after the A, most of these came on the SFX and others of teh same period, they tend to be a bit cheaper than the later lenses.
as for focal length, personally I find that I use my 28mm most for landscapes on film, but for digital I tend to use the kit lens (28 on the digital sensor ends up being neither wide enough, nor tight enough for any of my style)
Anything wider than 28mm give or take tends to be pretty costly since it was a fairly uncommon length in film days. And obviously anything digital related costs more, being newer.
