Originally posted by BATMON I usually shoot in TAV and keep the auto iso settings from 100 - 1600.
Should I just open it up from 100 - 51200?
Im using a K-50.
I recently moved it to 51200, and I was getting noisy photos when shooting a friend in warm light/nighttime/apt shots.
In TAv mode it should be safe to use whole ISO range, as ISO will depend on what you manually set shutter speed and aperture to.
If the camera choose higher ISO then than you prefer, you need to use slower shutter speed or larger aperture. If you cannot, then there are simply to little light available to use lower ISO. Limiting the ISO range in TAv will only add risk of underexposure.
If using semi-automatic modes you might want to limit ISO range as you do not have full control over shutter speed and aperture, but you can also try setting "auto ISO parameters" to slow, so the camera FI will use slower shutter speed before it start to raise the ISO (in Av mode).
