08-01-2015, 04:15 PM   #1
What? Why?
This morning I was out with my K20 taking photos in a local orchard. Everything was going well and I was looking forward to seeing them on my computer. I took a shot of a nest - looked at the screen to check it for exposure etc and saw a message. 'Cannot display this image' (or words to that effect). At that point I realised that all my lovely images were GONE!
The camera still won't take and retain a shot. The images I KNOW I had on the memory card don't seem to exist anymore.
Anyone got a clue about what is going on? Any ideas of ways to fix it? Currently it will take a photo and the back screen says Delete - the photo disappears into Never Never Land or somewhere and the message becomes 'Cannot display this image'. Very aggravating and disappointing.
08-01-2015, 04:21 PM   #2
QuoteOriginally posted by canajuneh Quote
Most likely the SD card's fault- have you tried a different card?
08-01-2015, 04:26 PM   #3
nozoom's Avatar
Could it be the memory card itself that is on its way into "Never Never Land or somewhere"? That would be my first thought. If you haven't already, try another one.
Cheers,
08-01-2015, 04:45 PM   #4
UncleVanya's Avatar
Broken sad card. Try new one. You can try to recover images using data recovery tools - doubtful it will work.
08-01-2015, 05:29 PM   #5
ramseybuckeye's Avatar
Did you format the card before using? This can happen with an unformatted card as well as a bad one.
08-01-2015, 05:58 PM   #6
Thanks for the suggestions folks. I tried a different memory card as recommended without success. Then I noticed that the top dial had moved - and instead of being set on Manual it had shifted two settings (past B to whatever that is after it!. I'm really not very technical I'm afraid.) I have no idea how the top dial got moved - but I recall it happened once before, but a long time ago so my aging memory didn't remember it in time to check it.
So between returning the camera to Manual and reformatting the memory cards the problem seems to be fixed. Well - apart from losing my images from this morning and possibly gaining a couple more grey hairs.
Sometimes I wonder how I learned new things, and fixed problems before computers came along and gave me access to wiser people like you guys.
08-01-2015, 07:39 PM   #7
Banned
Two clicks past "M" mode would be either "X" (flash sync) or Av (aperture priority). Either way, something should have been recorded and visible upon playback. Likely you have a bad / dying card or card slot. The "unable to display" message would be spawned by a read or write error, not an exposure one.
But that's just my opinion, I could be wrong.
08-02-2015, 12:47 PM   #8
Otis Memorial Pentaxian
I am glad you got things working
That being said, the warning you describe usually indicates a corrupted or unreadable file system on the SD card. The most common causes are removing the card (or camera USB cable) from the computer without a clean eject/dismount or doing a format using the computer. In those cases, an in-camera format is usually not possible*. There are also possible causes such as dirty/corroded contacts or a dying card.
* In that case, I recommend the format utility available from the SD Association Web site (LINK).
camera, display, images, message, pentax help, photo, photography, screen, shot, troubleshooting
What's your favorite K-mount Legacy lens & why? Docrwm Pentax SLR Lens Discussion 64 12-31-2016 07:30 AM
What would you choose, and why? ramseybuckeye Pentax SLR Lens Discussion 25 05-23-2015 04:46 PM
What Matters: Why the Camera Industry is in The Dumper And What Can be Done About It interested_observer Photographic Industry and Professionals 200 03-26-2014 09:38 AM
What and why DblArrow Troubleshooting and Beginner Help 13 02-16-2010 10:37 AM
What and Why??? Tom Lusk Post Your Photos! 5 02-08-2008 06:31 PM
All times are GMT -7. The time now is 02:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
