08-01-2015, 11:52 PM   #1
blurry sports photos
I'll be the first to admit I'm a novice photographer at best (translate - "soccer mum", love to take lots of action shots, but no skills). I have a Pentax K-X, which used to take brilliant photos on sports mode and in rapid sequence, clear enough to zoom in on the finished photos, crop and enlarge. Somewhere along the line it seems the camera settings have been changed (by me? by Junior photographers? inadvertently? ) and now in sports mode the photos are a little blurry, don't take the "rapid fire" as they used to and often are so bad I switch over to my iphone instead (and get better shots)
Have tried reset custom settings, tried the other reset function. Prior to this I tried a few things reading the manual, but while improved a bit, not like it was.......
Suggestions? (small country town, the place I bought it at closed down and we no longer have a camera store....)
Thanks!!
08-02-2015, 12:35 AM   #2
Imp
Imp's Avatar
switch to manual? =)
Sorry, i don't know about sports modes or anything. I would suggest learning to use the camera in manual mode, or in some of the semi-manual modes. In those modes, you should keep your shutter speed at 1/400th of second, or preferably higher, if you are seeking to freeze the action.
Could you post some of the settings that the camera chose for you in sports mode? When you view the picture, and it tells you the settings it used at the bottom, shutter speed, aperture, and iso. Perhaps compare those numbers to the numbers shown in the images that were good, and let us know if there is a difference.
As for the burst mode, try re-formating your memory card - warning, this will erase all images on your card. This is sort of like resetting the card, and it MIGHT operate a bit faster. Or try to see whether you've accidentally switched the burst mode to the "low" setting versus the "high" setting.
All the best!
08-02-2015, 12:53 AM   #3
AdrianM's Avatar
Would you be able to post one of the photos, and include info on the lens and the EXIF details (shutter speed, aperture, ISO etc) ? That would help determine what might be wrong. There are a range of things that cause blur eg. turning shake reduction off, inadequate shutter speed, using multi-point focus where there are too many things to focus on, too little depth of field, too slow shutter and camera shake.
08-02-2015, 01:05 AM   #4
UncleVanya's Avatar
Have you changed SD cards possibly? Do you delete pics on the card or transfer and then reformat?
08-02-2015, 05:59 AM   #5
mattt's Avatar
Shoot in Sv mode at 1/800 - or faster. Set drive mode to Hi and af to AF-C. Set ISO to Auto (3200 max).
That about covers Sports mode.
Note, If your camera pops up the flash disable auto flash as this will cap shutter speed.
08-02-2015, 06:20 AM   #6
QuoteOriginally posted by mattt Quote
I think you meant TAv?
08-02-2015, 06:30 AM   #7
mattt's Avatar
Ya that
Actually TV.... No TAv on a KX
08-02-2015, 08:53 AM   #8
Ya that
Oh, so Tv or Manual with Auto ISO right? I have a K-5II and I forget how the other cameras work sometimes.
camera, mode, pentax help, photography, photos, reset, settings, shots, sports, troubleshooting
soft/blurry photos below f8 with SMC Pentax-DA 18-55mm F3.5-5.6 AL II Capslock118 Troubleshooting and Beginner Help 21 11-26-2015 02:55 AM
Selling Digital Photos of Sports Events Neville Photographic Industry and Professionals 8 07-08-2014 09:37 AM
55-300mm photos blurry Reptilezz Pentax K-3 52 12-30-2013 01:28 AM
Frustrated: 77mm dog photos blurry SashasMom Troubleshooting and Beginner Help 52 05-27-2013 10:30 AM
Blurry photos - why? alysha1981 Troubleshooting and Beginner Help 10 04-28-2013 12:24 AM
All times are GMT -7. The time now is 07:10 AM. | See also: NikonForums.com, part of our network of photo forums!
