08-02-2015, 11:51 AM   #1
larryinlc's Avatar
K3 auto focus points.
Just received my new K3 and am going through the features. Changing auto focus points pushing the AF button while using either wheel does not change from spot on the lcd or the top dial. Now, I have only manual focus lens currently, so I'm wondering if this feature is disabled without an auto focus lens?
Larry
08-02-2015, 12:22 PM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by larryinlc Quote
The lens must have KAF, KAF2, or KAF3 mount in order to use other than the center AF point. The manual (p81) is a little confusing on this point since it shows conditional focus point select for series "A" lenses, the condition being that you are limited to center point spot only
08-02-2015, 12:24 PM   #3
jatrax's Avatar
Not positive but I believe on a manual focus lens you only get center point focus indication. It works that way on older lenses, not sure about new manual ones like the Samyang ones.
08-02-2015, 12:38 PM   #4
larryinlc's Avatar
Thanks. The lens I was using was a Zeiss Makro 50mm f2 manual lens. Not an old lens. I just tried a Rokinon 85mm and it does the same thing. I guess I need to buy an auto lens
08-02-2015, 01:13 PM   #5
Larry
You can only use AF point selection with A-type lenses, I believe. It's either that or AF lenses.
08-02-2015, 01:23 PM   #6
jatrax's Avatar
Does not work on my Pentax-A 50mm. I think it needs to be Pentax-F or newer.
08-02-2015, 01:24 PM   #7
larryinlc's Avatar
Adam. all my manual lenses are A lenses if this is what you mean?
08-02-2015, 02:00 PM   #8
Right, so then they need to me F type lenses or newer, i.e. with in-lens electronics that communicate with the camera. But if you put an AF lens in MF mode, you should still be able to select the AF points. That's what I was remembering
08-02-2015, 02:36 PM   #9
jatrax's Avatar
Yep, just tested that and that is how it works.
auto, camera, focus, k3, k3 auto focus, lens, pentax help, photography, troubleshooting
Is K3 Auto focus really that bad? GoldenRGuy Pentax K-3 66 07-24-2015 08:23 PM
Turn off auto focus on K3 Shutter Button Mark K5 Troubleshooting and Beginner Help 7 03-02-2015 01:30 PM
K3 auto focus Rligeski Pentax K-3 6 11-24-2014 09:52 PM
K3 - AF consistency using corner focus points MBT74 Pentax K-3 6 12-12-2013 08:40 AM
Auto focus points GLXLR Pentax DSLR Discussion 27 06-15-2009 03:20 PM
All times are GMT -7. The time now is 06:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
