08-03-2015, 03:24 AM   #1
LensBeginner's Avatar
Verifying an assumption on Av
Almost sure about this one.
M lens, forgot camera in Av mode, camera is metering wide open, and is not closing the aperture lever before shooting, correct?
Lens was set to f/8 and had shutter speeds in the order of 1/250s in M mode, 1/2000s or 1/3000 in Av.
08-03-2015, 03:38 AM - 1 Like   #2
MSL
MSL's Avatar
You are correct. For an M lens you either need to use M mode using the green button to do stop down metering, or adjust the aperture on the lens itself, but this can result is less accurate metering.
08-03-2015, 03:53 AM   #3
QuoteOriginally posted by MSL Quote
Yeah, that's what I always do (and what I cope with), but sometimes I have to switch to the 18-55mm WR in order to have a true wide angle, and that's when I forget to turn back the dial...
08-03-2015, 04:13 AM   #4
MSL
MSL's Avatar
QuoteOriginally posted by LensBeginner Quote
Some of my "best" recent photos ended up as 6Meg JPG files since I forgot to switch back that setting after I took a few shots for a warranty claim (so I didn't want to have to process large DNG files).
I also forget to switch between Av and TAv when opting for no flash/ flash - TAv doesn't like flash much.
One day I may get the hang of this.
08-03-2015, 04:34 AM - 1 Like   #5
paulh's Avatar
For an M or K lens (in M mode) you *do* have to set aperture on the lens dial, since there are no contacts to communicate with the camera body. Then use green button metering to set shutter speed. In Av mode, an M lens will only meter and shoot wide open.
08-03-2015, 05:02 AM   #6
MadMathMind's Avatar
TAv is *the* mode for HSS unless you want to go full M.
08-03-2015, 06:38 AM   #7
UncleVanya's Avatar
I thought it would meter wide open and stop down to what you had the aperture set Tobin the lens - rendering the exposure inaccurate. But it sounds like you guys are saying that setting Av mode disables the aperture from stopping down at all with an m series lens. Is that correct?
08-03-2015, 06:41 AM - 1 Like   #8
Yes. An M lens (bayonet, no contacts) will never ever stop down unless the camera is in (M)anual...
08-03-2015, 07:29 AM   #9
MSL
MSL's Avatar
Yes, @paulh is correct. Even in M mode you need to manually set the aperture on the lens. I use m42 lenses far more often than M ones, so this step kind of slipped my mind (as it is clearly mandatory with an m42)
08-03-2015, 08:06 AM - 1 Like   #10
You can "unscrew" M lens a bit and use it it even in P mode
---------- Post added 08-03-15 at 08:07 AM ----------
It will if you..unscrew/unmout it a bit
08-03-2015, 08:36 AM   #11
QuoteOriginally posted by AldaCZ Quote
Well yeah. You can remove the lever too. But then it is just like an m42 -- you can't meter wide-open...
08-04-2015, 12:45 AM - 1 Like   #12
That's what I occasionally do when I shoot a sunset for instance.
If you stop way down, it should reduce the amount of light on the sensor in LV (or on the viewfinder with the mirror down) compared to wide open and prevent damage.
That I only do when the sun is quite low and well in the "red", obviously, better safe than sorry...
av, bit, camera, lens, mode, pentax help, photography, troubleshooting
Confused about the AV jack on my 1000d Iksobarg Non-Pentax Cameras: Canon, Nikon, etc. 2 03-16-2015 08:05 PM
Blinking flash indicator in Av on K-5 Sal R Troubleshooting and Beginner Help 9 12-18-2014 10:48 AM
Av and Program Av Shift? CircaM Troubleshooting and Beginner Help 2 03-06-2013 12:13 AM
New camera mode idea: Av-R (Av Relative) Jonathan Mac Photographic Technique 6 04-15-2012 09:45 PM
Verifying Shake Reduction K100D newarts Pentax DSLR Discussion 7 12-19-2008 07:20 PM
All times are GMT -7. The time now is 11:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
