08-04-2015, 08:44 PM   #1
Universal TV remote code for Pentax
Hi
Would anyone know what code is applicable to Pentax K5 and/or K7? I am trying to use a "Oneforall 8" universal remote control. Your help will be greatly appreciated.
Regards
08-04-2015, 09:11 PM   #2
calsan's Avatar
I used to have a palm pilot. Yep, where are they now? Anyway there was a pentax remote for palm pilot. if you download it, open the readme file and it explains the infrared code for pentax.
IR remote shutter control for Pentax download | SourceForge.net
08-04-2015, 09:16 PM   #3
QuoteOriginally posted by calsan Quote
Hi
Thanks for the link, but what is a "palm pilot"?
08-04-2015, 09:17 PM   #4
Otis Memorial Pentaxian
clackers's Avatar
Try the one for Canon, El Baroda.
08-04-2015, 09:17 PM   #5
The same code should work for all Pentax dSLRs.
08-04-2015, 09:22 PM   #6
Hi. Thanks for your input but Canon is not in the list of codes. I am trying to use a universal TV/VCR/DVD remote so I don't think it will show any camera code. But I understand that one/some TV codes will work with a dslr, including Pentax.
---------- Post added 08-05-2015 at 02:24 PM ----------
Hi Steve. Can you please be more specific? Which code is it? Thanks.
08-04-2015, 09:45 PM   #7
clackers's Avatar
QuoteOriginally posted by el baroda Quote
You're out of luck, then,
If you can get it to do this (taken from Calsan's link), great:
"The remote control generates a series of IR pulses as shown below. The 'on'-
pulses are modulated at 38kHz.
38kHz ---> ||||||||||||| ||| ||| ||| ||| ||| ||| |||
modulation _|||||||||||||_________|||___|||___|||___|||___|||___|||___|||_
duration [ms] | 13 | 3 |1| 1 |1| 1 |1| 1 |1| 1 |1| 1 |1| 1 |1|
This waveform is approximated in the Palm device by setting the baud rate to
38000 and sending sequences of characters of all ones or all zeros to the IR
UART. The end result is not exactly the same, but it seems to work fine."
If your remote can learn IR, borrow a friend's Canon remote (for their lower end models) to teach it the sequence.
08-04-2015, 09:48 PM   #8
UncleVanya's Avatar
This is the first I have heard of this. As cheap as remotes are why????
08-04-2015, 10:04 PM - 1 Like   #9
I bought a cheap remote not long ago but its range is too short and it not IR. I have read success stories using universal tv remote control but can't find the link anymore. Hopefully, someone here has gone that road and will let me know how to do it. Cheers.
08-04-2015, 10:08 PM   #10
UncleVanya's Avatar
Seems interesting.
08-04-2015, 10:12 PM   #11
Most remotes have a setup method where you use the channel buttons to scroll through frequencies to find the one your device will respond to. Try setting up the camera in remote mode and just scrolling through the remote outputs till you get a shutter release.... Or is it not that simple?
08-04-2015, 10:16 PM   #12
If your remote only lists TV stuff, your guess would be as good as mine. If you have an Android SmartPhone, you might be interested in the DSLR Remote App (by bitshift). If provides excellent Pentax support using the phone's IR blaster.
08-04-2015, 11:08 PM   #13
QuoteOriginally posted by wibbly Quote
Thanks a lot. Will give this a go and let you know. Cheers.
---------- Post added 08-05-2015 at 04:09 PM ----------
Thanks, Steve. Will try.
08-05-2015, 12:22 AM   #14
Cpt. Obvious here: Your phone must of course have an IR transmitter built in. I suggest going to GSMArena to check the specs.
08-05-2015, 01:45 AM   #15
QuoteOriginally posted by Giklab Quote
Hi. Just confirmed that my phone model does not have it. Thanks.
camera, canon, code, codes, pentax, pentax help, photography, steve, thanks, troubleshooting, tv remote code
CODE GIVEN AWAY. {I have a KEH code for 7% off, who wants it?} PBandJ Pentax Price Watch 10 09-11-2013 08:22 AM
Pentax Kx code for universal remotes!!! Andrew Lang Pentax DSLR Discussion 5 02-13-2010 09:59 PM
universal remote tom_kkh Troubleshooting and Beginner Help 14 02-09-2010 01:25 PM
TV Remote? stgmgr Photographic Technique 6 02-21-2009 03:44 PM
IST D Infrared Remote code oilfield trash Pentax DSLR Discussion 7 07-01-2007 08:47 PM
All times are GMT -7. The time now is 04:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
