08-11-2015, 08:35 AM   #1
k-s2 firmware update
can not upgrade to 1.10, even though followed both methods on upgrade video.
previously upgraded to 1.02.
anyone help?
08-11-2015, 08:57 AM   #2
jatrax's Avatar
The normal things to check:
1) you must extract the .bin file from either the .zip or the windows .exe
2) you must place the .bin in the root of your SD card, not in any folder
If you did those, maybe double check you have the correct firmware or re-download.
08-11-2015, 01:20 PM   #3
followed all the steps again and same result. display opens to the normal shooting window. here's the name of the extracted file-fwdc225b-1.bin.
anyone with any answers?
08-11-2015, 03:22 PM   #4
The file name should be fwdc225b.bin
There is a problem with how you are doing the extraction. Before you try again, you might want to confirm the installed version. It may be that your previous attempt did work.
08-11-2015, 06:47 PM   #5
k-s2 firmware
thought the -1 might be causing the problem. didn't want to change anything without some outside conformation. will try first thing tomorrow. thanks.
08-12-2015, 05:01 AM   #6
did it and all's good.
camera, k-s2, k-s2 firmware, pentax help, photography, troubleshooting, upgrade
K-S2 Firmware 1.02 mrg9999 Pentax K-S1 & K-S2 2 07-20-2015 06:28 AM
New Firmware Update v1.02 for PENTAX K-S2 ogunturkay Pentax News and Rumors 2 06-30-2015 06:16 PM
K-7 firmware update Dickie 43 Troubleshooting and Beginner Help 11 09-14-2014 07:02 AM
K-50 Firmware Update Paul Katinas Pentax K-30 & K-50 2 07-04-2014 09:33 AM
K-500 Firmware Update mmarquardt Troubleshooting and Beginner Help 9 06-26-2014 08:36 PM
All times are GMT -7. The time now is 04:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
