Originally posted by jatrax Dust removal procedure in order:
- Use the camera dust removal system. There is a menu setting to turn on/off. If you have dust run this several times in a row and then check for dust again. I leave mine on "run on startup" and I think that is best so you don't have to worry about it.
- Use a 'rocket blower' or equivalent to blow off anything the shaker will not get rid of. Do not use compressed air or canned air. Some folks report it is OK to use canned air if you are careful, personally I'm not taking any chances but YMMV. You have to lift the mirror in order to do this. Use the cleaning function in the menu.
- Use a wet cleaning kit. This is the last resort, and on two cameras with over 25,000 actuations in all kinds of environments I've never had to use one yet. Get this if all else fails but don't go there unless you are sure you need it.
- Send in for professional cleaning. Pentax extended warranty (in the US) includes one 'free' cleaning. Not sure about anywhere else.
Easiest way to check for dust is to set your aperture to f/22 or so and take an image of the sky. Dust on the sensor is more visible at smaller apertures.
Thanks a lot for that detailed list Jatrax; it's much appreciated.
I already have dust removal enabled on StartUp - so point one is ticked off.
I don't have a rocket blower, but one's ordered - so point two ticked off, too.
And hopefully that will get me through this. Thanks again for your advice.
---------- Post added 08-13-15 at 02:24 PM ----------
Originally posted by jatrax So we should keep a distance from any Canon sensors to avoid contamination? OP must have got too close..............
I did see a lot of Canons so one of these snakes must have jumped. Will keep further away from them in future!
---------- Post added 08-13-15 at 02:25 PM ----------
Originally posted by stevebrot Poppy cock! That is a flying snake. They are attracted to digital image sensors.
And that's what I thought too!
